Dock gets "stuck" and won't autohide, fixes itself if you try to configure it
root=UUID=0f293667-6ba2-4617-b351-21cdbb1f9ccd rw rootflags=subvol=@
quiet rd.luks.uuid=5dc4e883-7d4f-4a0c-9a7c-b9772d952214 loglevel=3
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X421FAY_K413FA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X421FAY v: 1.0 serial: <filter>
uuid: 00f9b479-38bb-1a4e-8fc5-8bee5453389b UEFI: American Megatrends
v: X421FAY.304 date: 01/04/2021
ID-1: BAT0 charge: 15.9 Wh (56.2%) condition: 28.3/42.1 Wh (67.2%)
power: 20.8 W volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: charging cycles: 661
Info: model: Intel Core i3-10110U socket: BGA1528 (U3E1) note: check
bits: 64 type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 10
level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0x100
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3300 min/max: 400/4100 base/boost: 2673/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
cores: 1: 3300 2: 3300 3: 3300 4: 3300 bogomips: 20799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9b41
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 13d3:56a2
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14e5 built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1920x1080
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
device-ID: 8086:9b41 memory: 1.77 GiB unified: yes
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 25.0.5-arch1.1
device-ID: 8086:9b41 surfaces: N/A device: 1 type: cpu name: llvmpipe
Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.14.6-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.2 status: n/a (root, process) with:
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 55.01 GiB (11.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 tech: SSD serial: <filter> fw-rev: 005C temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 81d 12h cycles: 3,093
read-units: 404,860,856 [207 TB] written-units: 140,641,226 [72.0 TB]
ID-1: / raw-size: 69.67 GiB size: 69.67 GiB (100.00%)
used: 54.79 GiB (78.6%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 253:0 mapped: luks-5dc4e883-7d4f-4a0c-9a7c-b9772d952214
ID-2: /boot/efi raw-size: 954 MiB size: 952.1 MiB (99.80%)
used: 228.9 MiB (24.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 69.67 GiB size: 69.67 GiB (100.00%)
ID-4: /var/log raw-size: 69.67 GiB size: 69.67 GiB (100.00%)
ID-5: /var/tmp raw-size: 69.67 GiB size: 69.67 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.24 GiB used: 1.43 GiB (19.7%)
max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 72.0 C pch: 55.0 C mobo: N/A
Fan Speeds (rpm): cpu: 5600
Memory: total: 4 GiB available: 3.62 GiB used: 2.38 GiB (65.7%) igpu: 64 MiB
Processes: 271 Power: uptime: 6m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 1.42 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1473 libs: 416 tools: octopi,paru Compilers:
gcc: 15.1.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
System install date:     2025-02-12
Last full system update: 2025-05-20
Windows dual boot:       Yes
Failed units:            nmb.service
Video to illustrate the issue → https://files.catbox.moe/pdai75.webm
The dock doesn’t go away but if you try to edit its settings it starts working as intended.
Have you tried booting into x11 to check its not wayland?
Try switching to another global theme (for example Breeze) and then back again, or use:
lookandfeeltool --resetLayout --apply Mokka
Alright ill try this and report back!
