DistroBox "kernel does not support overlay fs"
Error: configure storage: kernel does not support overlay fs: ‘overlay’ is not supported over btrfs at “/home/jdfoiejife/.local/share/containers/storage/overlay”: backing file system is unsupported for this graph driver
Create it now, out of image registry.fedoraproject.org/fedora-toolbox:latest? [Y/n]:
Kernel: 6.14.9-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 15.1.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=ae2423f0-deb7-4c93-839e-8c1e50dc6871 rw rootflags=subvol=@
quiet rd.luks.uuid=c81a926c-abfd-44bd-88f3-7903c6806431
rd.luks.uuid=b2e08dcf-2495-47de-9445-b93a2d46c4bc
resume=/dev/mapper/luks-b2e08dcf-2495-47de-9445-b93a2d46c4bc loglevel=3
Type: Mini-pc System: Micro (HK) Tech product: Venus series v: N/A
Mobo: Shenzhen Meigao Equipment model: F7BSC serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.09
date: 11/20/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
microcode: 0xA704107
Speed (MHz): avg: 1575 min/max: 400/5263 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1575 2: 1575 3: 1575
4: 1575 5: 1575 6: 1575 7: 1575 8: 1575 9: 1575 10: 1575 11: 1575 12: 1575
13: 1575 14: 1575 15: 1575 16: 1575 bogomips: 127765
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-1, DP-2, DP-3,
DP-4, DP-5, DP-6, DP-7, HDMI-A-1, Writeback-1 bus-ID: c5:00.0
chip-ID: 1002:15bf class-ID: 0300 temp: 47.0 C
Monitor-1: HDMI-A-2 model: Samsung S34CG50 serial: <filter> built: 2024
res: mode: 3440x1440 hz: 100 scale: 114% (1.15) to: 2991x1252 dpi: 109
gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes:
max: 3440x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi phoenix
LLVM 19.1.7 DRM 3.61 6.14.9-hardened1-1-hardened) device-ID: 1002:15bf
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV PHOENIX) driver: mesa radv v: 25.1.1-arch1.2
device-ID: 1002:15bf surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.1.1-arch1.2 (LLVM
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: c5:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: c5:00.5 chip-ID: 1022:15e2 class-ID: 0480
bus-ID: c5:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.9-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.4 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 8087:0032
Local Storage: total: 2.05 TiB used: 11.97 GiB (0.6%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 35.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
used: 11.97 GiB (6.0%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-c81a926c-abfd-44bd-88f3-7903c6806431
used: 776 KiB (0.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
ID-3: /home raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-4: /var/log raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-5: /var/tmp raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-1: swap-1 type: partition size: 32.07 GiB used: 0 KiB (0.0%)
mapped: luks-b2e08dcf-2495-47de-9445-b93a2d46c4bc
ID-2: swap-2 type: zram size: 29.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 48.0 C
Memory: total: 32 GiB note: est. available: 29.15 GiB used: 3.13 GiB (10.7%)
Processes: 411 Power: uptime: 20m states: freeze,mem suspend: s2idle
wakeups: 0 services: org_kde_powerdevil, power-profiles-daemon, upowerd
Packages: pm: pacman pkgs: 1385 libs: 388 tools: octopi,paru Compilers:
inxi: 3.3.38
System install date:     2025-05-30
Last full system update: 2025-06-03
Failed units:            systemd-hibernate-resume.service
If you take hardened you definitely need to live with things like these not working. I’m very sure it’s the cause, verify by using regular linux(-zen). I may be wrong, but it breaks some of the fancy stuff for sure.
