Hi there
This is a strange one. I get my images distorted, every time I upload OR download them over ANY browser.
So both Firedragon and Chrome happen to do that. Both in the same manner, the distortion seems to happen in a specific way.
Mind, that this happens both when I upload a correct image to some platform via my browser, and also when I download a correct image on the same way.
I cannot image, what part of the OS might do that, so maybe you can help me.
All is updated, this happens since around two days worth of upgrades.
Edit: It happens on the Macbook of my girlfriend too. I have no idea how this could be connected to something shared between both devices.
Then I can download pictures from my Android and her iPhone completely fine from apps like WhatsApp and Telegram, and get the same issue with browsers.
Cross-platform cross-browser, but browser-only related bug.
This seems extra weird.
See the original photo here on the right side and how it lands on my computer, shown by Gwenview.
Same here with Facebook in reverse, so by uploading:
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=46338def-99f4-4c88-a1c9-c25c5c3e3b6a rw rootflags=subvol=@
Mobo: ASUSTeK model: PRIME B550-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0320
date: 05/13/2020
Info: model: AMD Ryzen 5 3500X bits: 64 type: MCP arch: Zen 2
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 3949 high: 3950 min/max: 2200/4521 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3949 2: 3950
3: 3950 4: 3949 5: 3950 6: 3950 bogomips: 47403
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: DVI-D-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 06:00.0 chip-ID: 1002:67df class-ID: 0300
Monitor-1: DVI-D-1 mapped: DVI-D-0 model: MAGIC LCD 222 serial: <filter>
built: 2010 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 480 Graphics (polaris10 LLVM 13.0.1 DRM
3.44 5.17.9-zen1-1-zen)
v: 4.6 Mesa 22.1.0 direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Local Storage: total: 1.48 TiB used: 889.84 GiB (58.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD size: 111.79 GiB
serial: <filter> rev: 6A0 scheme: GPT
model: WD10EZEX-75WN4A1 size: 931.51 GiB block-size: physical: 4096 B
rev: 7113 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Generic
model: STORAGE DEVICE size: 238.3 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1206 scheme: MBR
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
used: 97.02 GiB (87.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 1.25 GiB (8.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 58.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 861
Processes: 308 Uptime: 3h 26m wakeups: 0 Memory: 15.58 GiB
used: 8.03 GiB (51.6%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1904 lib: 529 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-03-01
Last full system update: 2022-05-25
Failed units: bluetooth-autoconnect.service systemd-networkd-wait-online.service
