Hello.
I recently installed Garuda on my PC and ever since, I have been experiencing a distorted graphics related problem. Let me explain in detail.
Whenever I wake up my PC from sleep and try to open any stale windows , the graphics gets distorted (see pictures below). For example I am using Visual code Studio, and I put my PC to sleep (with VS code window still open). When I start the PC after some time, and open VS code from, it goes all black and distorted. The only solution is to re-start the PC.
Since my PC has dual boot (windows and Garuda), I thought I need to upgrade windows BIOS, but that did not help. I also tried updating Nvidia Graphics driver both in Garuda and Windows, but no help.
Is there any possible solution to this issue?
Here is the system information:
inxi -Faz
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=7349e67d-eaa6-4bbb-81ae-787c5283a4f1 rw rootflags=subvol=@
resume=UUID=45a313d6-3343-4216-8389-6c025119b6c8 loglevel=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.G3
date: 09/26/2021
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2436 high: 4363 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4363 2: 2105
3: 2057 4: 2196 5: 2200 6: 2199 7: 2199 8: 2199 9: 2195 10: 2057 11: 3600
12: 2057 13: 3502 14: 2101 15: 2057 16: 2198 17: 2195 18: 2196 19: 2199
20: 2199 21: 2199 22: 2056 23: 4038 24: 2098 bogomips: 182396
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Micro-Star MSI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0
chip-ID: 10de:1e89 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9")
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:10f8
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: down mac: <filter>
IF-ID-1: vpn0 state: up speed: 10 Mbps duplex: full mac: N/A
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:2 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 2.27 TiB used: 1017.27 GiB (43.7%)
model: SSD 970 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXE7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 23.25 GiB (46.5%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 114.41 GiB size: 114.41 GiB (100.00%)
used: 17.07 GiB (14.9%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
used: 23.25 GiB (46.5%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%)
ID-1: swap-1 type: partition size: 30 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.6 GiB used: 158.2 MiB (1.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 517 Uptime: 3h 22m wakeups: 0 Memory: 15.6 GiB
used: 7.16 GiB (45.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1496 pacman: 1490 lib: 347 snap: 6 Shell: Bash
v: 5.1.12 running-in: konsole inxi: 3.3.11
Here are some screenshots of the distorted graphics:
https://drive.google.com/drive/folders/1DzzDXx3ftRCyDejUk39Oqlaq8kr5F74X?usp=sharing
