Whenever I use sleep mode, and then wake the computer, I get a system report, and the only way to correct is to either log out and back in, or restart the computer.
Steps to reproduce:
Click User Switcher icon in top right corner
Click Leave
Click Sleep
Wake computer
Expected Result: Computer wakes normally, user can resume operation with no issues
Actual Result: Screen becomes distorted, sometimes unusable
I am a new user, so I am unable to attach screenshots. The notification is from KWin Window Manager, stating, "Desktop effects were restarted due to a graphics reset".
Thanks in advance! Lets me know if there are any questions or additional info needed.
Below is my output from garuda-inxi:
Kernel: 5.16.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c99ea8d7-6cc0-4044-990f-7a14c0ba1451 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING/AURA v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2003
date: 09/19/2016
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3949 high: 3991 min/max: 800/4000 scaling:
driver: intel_pstate governor: performance cores: 1: 3902 2: 3857 3: 3987
4: 3971 5: 3973 6: 3991 7: 3980 8: 3938 bogomips: 54398
Type: l1tf
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga.com.
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c02 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: NVIDIA GP106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
Device-3: Corsair ST100 Headset Output type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6.1:5 chip-ID: 1b1c:0a32
Sound Server-1: ALSA v: k5.16.3-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad
bus-ID: 1-2:2 chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
Local Storage: total: 1.38 TiB used: 27.64 GiB (2.0%)
model: WDS256G1X0C-00ENX0 size: 238.47 GiB block-size: physical: 512 B
rev: B35900WD temp: 54.9 C scheme: MBR
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU900 size: 238.47 GiB
serial: <filter> rev: 6A scheme: GPT
used: 27.64 GiB (11.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.56 GiB used: 512 KiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 48 C
Processes: 277 Uptime: 1m wakeups: 0 Memory: 15.56 GiB
used: 3.13 GiB (20.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1812 lib: 506 Shell: fish v: 3.3.1
default: Zsh v: 5.8 running-in: konsole inxi: 3.3.12
Garuda:
System install date: 2022-01-28
Last full system update: 2022-01-30
Using TLP: No
