Hello World!, Hope you're doing well, my name is Samu, I'm a CS student beginner as Linux user, I've tried manjaro and mainly in WSL Ubuntu and Debian, so beforehand let me excuse myself if this post is not helpful to look into my problem.
Alright, so I've been trying to get DisplayLink to work multiple times in the versions of Garuda Dragonized and Dragonized Gaming with no success whatsoever.
On my last attempt (Done in the Garuda Dragonized ed Downloaded and flashed with Garuda Downloader) i think I've narrow the trouble down to the Evdi not showing up as a DRI more on this later.
So i did as follows:
- First did AUR guide on DL (Installed evdi-git since it does support Linux 6.0 Pull 381), all the way up to the installation and stomping with this problem to config it accordingly for Xorg (I don't know if this ver of the distro supports wayland). modesetting doesn't shows up.
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x54 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 2 associated providers: 1 name:Unknown AMD Radeon GPU @ pci:0000:04:00.0
Provider 1: id: 0x1fb cap: 0x2, Sink Output crtcs: 4 outputs: 2 associated providers: 1 name:NVIDIA-G0
- On finding this i made sure, UDLFB module is not present
modinfo udlfb
modinfo: ERROR: Module udlfb not found.
- Made sure UDL and EVDI where active modules
modinfo udl evdi
filename: /lib/modules/6.0.6-zen1-1-zen/kernel/drivers/gpu/drm/udl/udl.ko.zst
license: GPL
srcversion: 37D63C3C77324181BC3E760
alias: usb:v17E9p*d*dc*dsc*dp*icFFisc00ip00in*
depends:
retpoline: Y
intree: Y
vermagic: 6.0.6-zen1-1-zen SMP preempt mod_unload
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 73:3F:F3:EF:5C:32:78:5D:0C:43:B6:C8:3D:CF:63:E1:0C:20:FC:27
sig_hashalgo: sha512
signature: 30:64:02:30:08:BD:62:1D:E0:8A:68:C6:4F:DD:09:78:EC:E4:19:30:
ED:10:C5:95:2D:EE:67:60:5C:E5:50:66:82:3F:BB:38:E4:AE:3E:68:
41:F4:97:11:29:B3:3B:CE:F2:D6:F0:CF:02:30:2C:E9:99:69:8F:E0:
38:32:91:7D:22:56:3E:D4:C8:66:20:65:C3:9B:08:81:B8:0B:6C:B6:
45:DC:B3:61:66:63:A3:18:63:A8:A2:92:6C:A8:DD:3D:69:29:01:AB:
A9:F4
filename: /lib/modules/6.0.6-zen1-1-zen/updates/dkms/evdi.ko.zst
license: GPL
description: Extensible Virtual Display Interface
author: DisplayLink (UK) Ltd.
import_ns: DMA_BUF
import_ns: DMA_BUF
srcversion: 4974DD71AA25227D00FFEC9
depends:
retpoline: Y
sig_id: PKCS#7
signer: DKMS module signing key
sig_key: 35:E3:5A:18:1F:46:34:BF:DA:D5:99:EA:ED:DF:32:27:0B:21:CB:15
signature: A7:6A:CA:71:D9:12:EA:BD:0C:2A:94:C5:E8:46:A8:C8:86:75:3B:D5:
65:2D:73:5E:A1:BF:22:94:EF:08:1C:B7:81:9F:B3:70:7D:13:0C:83:
6F:8E:76:5A:26:69:2B:DD:8A:56:97:08:AD:9D:E1:A7:85:9A:F6:02:
BD:9E:E0:4F:E6:AD:93:22:8C:37:98:87:EC:A2:A2:3B:FA:6E:A9:A0:
8B:12:AE:DE:A6:AB:BB:71:AE:1A:96:8B:3E:23:E3:D7:5E:6D:C2:72:
21:F5:E3:5C:4A:7B:DE:70:FC:44:F8:B1:AC:8D:70:37:20:F4:A8:D8:
4C:5B:4C:E5:AC:90:13:94:1F:18:55:35:7B:7C:64:0F:82:89:E2:CD:
68:C0:DD:BA:A6:56:4F:74:E8:04:3D:D9:D4:A8:D2:33:08:46:B0:CD:
32:51:BE:F5:DD:AD:09:16:DC:AD:94:7D:CD:A2:46:E0:15:B7:41:36:
EF:FD:A5:BD:F7:32:05:BB:C4:9A:9E:B8:49:F2:B8:E7:AF:25:BC:A2:
ED:1E:B7:71:29:45:D0:D7:62:F9:21:42:2B:4A:01:19:7E:AB:AC:C6:
A9:58:89:2C:9E:23:0B:68:1A:17:DB:F9:99:9E:CC:EA:4C:BB:D6:B0:
45:46:1A:24:0A:CE:25:6F:3B:F5:DC:31:0C:D6:B0:60
parm: initial_loglevel:Initial log level (int)
parm: initial_device_count:Initial DRM device count (default: 0) (ushort)
- Check displaylink.service is up # To note: This service wasn't active when i restarted
systemctl status displaylink.service
● displaylink.service - DisplayLink Manager Service
Loaded: loaded (/usr/lib/systemd/system/displaylink.service; disabled; preset: disabled)
Active: active (running) since Tue 2022-11-01 13:29:59 -03; 52min ago
Process: 3032 ExecStartPre=/sbin/modprobe evdi (code=exited, status=0/SUCCESS)
Main PID: 3036 (DisplayLinkMana)
Tasks: 14 (limit: 28078)
Memory: 15.2M
CPU: 1.334s
CGroup: /system.slice/displaylink.service
└─3036 /usr/lib/displaylink/DisplayLinkManager
nov 01 13:29:59 fxsamu systemd[1]: Starting DisplayLink Manager Service...
nov 01 13:29:59 fxsamu systemd[1]: Started DisplayLink Manager Service.
- Checking on the Troubleshooting Optimus + DL i found out that running
ls -al /dev/dri/by-path
drwxr-xr-x - root 1 nov 13:27 .
drwxr-xr-x - root 1 nov 13:27 ..
lrwxrwxrwx@ 8 root 1 nov 13:27 pci-0000:01:00.0-card -> ../card1
lrwxrwxrwx 13 root 1 nov 13:27 pci-0000:01:00.0-render -> ../renderD129
lrwxrwxrwx@ 8 root 1 nov 13:27 pci-0000:04:00.0-card -> ../card0
lrwxrwxrwx 13 root 1 nov 13:27 pci-0000:04:00.0-render -> ../renderD128
Does not show evdi as DRI, Here is where I'm in a dead end since i actually don't have a clue where or when does that evdi should show up. It's possible that I'm totally wrong and there's just this small step that i didn't check but pretty much everything that i could search on evdi git, aur or garuda forums was unable to help me move pass this point, please help ![]()
Garuda inxi as required!
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=caff0e71-4434-490e-802b-0b0c7d59ae3f rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401IV_GA401IV
Mobo: ASUSTeK model: GA401IV v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GA401IV.220 date: 03/14/2022
ID-1: BAT0 charge: 65.2 Wh (100.0%) condition: 65.2/76.0 Wh (85.9%)
status: not charging
Info: model: AMD Ryzen 7 4800HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7
(7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1948 high: 4291 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2900 2: 1397
3: 1469 4: 1400 5: 1511 6: 1371 7: 1615 8: 1400 9: 4291 10: 3978 11: 1907
12: 1400 13: 1907 14: 1618 15: 1400 16: 1613 bogomips: 92627
protection
Device-1: NVIDIA TU106M [GeForce RTX 2060 Max-Q] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f12 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 42.0 C
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Monitor-1: DP-1-0 size-res: N/A modes: N/A
Monitor-2: eDP pos: primary res: 1920x1080 hz: 60 dpi: 158
size: 309x174mm (12.17x6.85") diag: 355mm (13.96") modes: N/A
OpenGL: renderer: RENOIR (renoir LLVM 14.0.6 DRM 3.48 6.0.6-zen1-1-zen)
v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 5-2.2:6 v: kernel chip-ID: 0951:170b pcie:
class-ID: 0300 gen: 1 speed: 2.5 GT/s serial: <filter> lanes: 8 link-max:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-5: Kingston HyperX Cloud Stinger Core Wireless + 7.1 type: USB
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 4-1:2 chip-ID: 0bda:8153 class-ID: 0000
IF: enp4s0f3u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 5-4:5 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.85 TiB used: 9.26 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS2000G
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: S8442105 temp: 30.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 250 GiB size: 250 GiB (100.00%) used: 9.24 GiB (3.7%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 28.5 MiB
(29.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 250 GiB size: 250 GiB (100.00%) used: 9.24 GiB
(3.7%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 250 GiB size: 250 GiB (100.00%) used: 9.24 GiB
ID-5: /var/tmp raw-size: 250 GiB size: 250 GiB (100.00%) used: 9.24 GiB
ID-1: swap-1 type: zram size: 22.9 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.8 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): cpu: 2600
Processes: 381 Uptime: 22m wakeups: 4 Memory: 22.9 GiB used: 5.28 GiB
(23.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1199 libs: 308
running-in: yakuake inxi: 3.3.22
e[1;34mGaruda (2.6.9-1):e[0m
e[1;34m System install date:e[0m 2022-11-01
e[1;34m Last full system update:e[0m 2022-11-01 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
