Display wake up 'half way'
Hi together, first my system:
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4e56ecf0-49d1-4b02-88c7-e198d37becdf rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop Mobo: Micro-Star model: MEG X570 UNIFY (MS-7C35) v: 2.0
Megatrends LLC. v: A.F0 date: 03/01/2023
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3400 min/max: 2200/5083 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400 3: 3400
4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400 20: 3400
21: 3400 22: 3400 23: 3400 24: 3400 25: 3400 26: 3400 27: 3400 28: 3400
29: 3400 30: 3400 31: 3400 32: 3400 bogomips: 217593
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Gigabyte driver: nvidia
v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 2d:00.0 chip-ID: 10de:2684
display-ID: 0
Monitor-1: DP-1 res: 3840x2160 size: N/A modes: N/A
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 560.35.03
device-ID: 10de:2684 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: NVIDIA AD102 High Definition Audio vendor: Gigabyte
bus-ID: 2d:00.1 chip-ID: 10de:22ba class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 27:00.0
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
Local Storage: total: 7.97 TiB used: 158.48 GiB (1.9%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 40.9 C
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 46.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
tech: SSD serial: <filter> fw-rev: 6B0Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Mushkin model: MKNSSDRE1TB
tech: SSD serial: <filter> fw-rev: 6A scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT4000MX500SSD1
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
used: 158.48 GiB (17.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 256 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 48.9 C mobo: N/A
Memory: total: 32 GiB available: 31.26 GiB used: 4.28 GiB (13.7%)
Processes: 525 Power: uptime: 56m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2001 libs: 564 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-06-09
Last full system update: 2024-09-25
when my system wake up from sleep, test system settings and
systemctl suspend
the display shows only distortion desktop grafik. Icons and windows cut in half etc. sometimes its only black. Nothing clickable. Tty run.
Try lts and linux kernel instead of zen also x11 session instead wayland takes no changes. Read something about kernel modules… hope find an easy solution (beginner)
Come from ubuntu gnome x11 there was fine also win10.
Thx Markus
Try setting up " Preserve video memory after suspend" as described here: NVIDIA/Tips and tricks - ArchWiki
You can add a kernel module parameter by creating a config in etc/modprobe.d/ with an editor, for example with Micro:
sudo micro /etc/modprobe.d/nvidia-preserve-memory.conf
Paste in the options for the kernel module parameter:
options nvidia NVreg_PreserveVideoMemoryAllocations=1
Save and exit out of the file. Then rebuild the initramfs.
sudo dracut-rebuild
Finally, enable the services mentioned in the article.
sudo systemctl enable --now nvidia-suspend.service nvidia-hibernate.service nvidia-resume.service
I hope that helps, welcome to the community @Buchquetscher. :wave:
Hi,
thanks for your instant help, working fine now. I was really ready to give up on Garuda :wink:
Great to be here!
Better you simplify your life and give up on Nvidia if you intend to stick with Linux. :wink: :smiley:
Way to pull off a fix on the very first reply @BluishHumility, nice work. :+1:
