Display settings not saving
Hello,
It’s not a critical problem but every time I reboot my PC, I have to redo my display settings everytime. I would like to know where display config are saved?
Should I use System Settings or Nvidia X server settings?
Here is my garuda-inxi
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=78100126-603a-4cdb-b45c-0b95512a124a rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: ROG STRIX B760-F GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1402
date: 09/08/2023
ID-1: hidpp_battery_0 charge: 51% condition: N/A volts: 3.8 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: 13th Gen Intel Core i5-13600KF bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 963 high: 1100 min/max: 800/5100:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1100 3: 1100
4: 1100 5: 1100 6: 800 7: 1100 8: 1100 9: 1100 10: 1100 11: 1065 12: 1100
13: 800 14: 799 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
bogomips: 139776
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Gigabyte driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-1,DP-2 empty: DP-3,HDMI-A-1,HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:2206 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 5120x1440 s-dpi: 92 s-size: 1413x393mm (55.63x15.47")
s-diag: 1467mm (57.74")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,right
model: LG (GoldStar) 32GK850G serial: <filter> built: 2010 res: 2560x1440
dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
Monitor-2: DP-2 note: disabled pos: left model: Acer XB271HK
serial: <filter> built: 2016 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
max: 3840x2160 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 545.29.06
device-ID: 10de:2206 surfaces: xcb,xlib
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: NVIDIA GA102 High Definition Audio vendor: Gigabyte
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:8
Device-4: Logitech Blue Microphones
lanes: 1 mode: 2.0 bus-ID: 1-9.4:14 chip-ID: 046d:0ab7 class-ID: 0300
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel
chip-ID: 8086:125c class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12 chip-ID: 8087:0033
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 3.21 TiB used: 835.87 GiB (25.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 530
ZP1000GM30023 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU6SM003
temp: 29.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 25.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: R031 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 QVO 1TB
used: 63.85 GiB (13.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 31.15 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 454 Uptime: 6m wakeups: 0 Memory: total: 32 GiB
available: 31.15 GiB used: 4.89 GiB (15.7%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1861
pm: pacman pkgs: 1851 libs: 523 tools: octopi,pamac,paru,yay pm: flatpak
pkgs: 10 Shell: fish v: 3.6.4 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-12-08
Last full system update: 2023-12-14
I prefer to use the system settings rather than NVIDIA control panel because occasionally the NVIDIA settings will go wonky with an update.
Either will work, but don’t try and use both at the same time.
ALright, any idea with my system setting are reseting at every reboot?
Where are you trying to set them? In NVIDIA settings or your Display Settings?
If NVIDIA settings, it’s likely you’re not saving the config in the right place. You need to run nvidia-settings as root to be able to save the config.
I’m trying in NVIDIA setting but I launch it via the GUI. I’ll try in root.
Thank you
Still doesn’t work I’m out of ideas :sweat_smile:
