Bug report on New iso.
On this hardware, Wayland does not let me change desktop resolution (defaults to 1024x7xx). It seems to be the case on other Wayland ISO’s as well.
There’s not a lot on this issue online. I don’t know what unsupported means here. Is 1920x1200 not supported or is the display not supported?
A data point.
I wonder too, if there is going to be xorg legacy solution, would be beneficial on older hardware (the oldies here are Dell Ultrasharp Ips monitors).
➜ ~ garuda-inxi
Kernel: 6.5.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cd4e199c-5699-4822-9f3c-b5e74d75ff6c rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3604
date: 02/25/2022
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3507 high: 3700 min/max: 2200/3700 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2406 2: 3239
3: 3700 4: 3700 5: 3700 6: 2973 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700
12: 3700 13: 3700 14: 3094 15: 3700 16: 3700 bogomips: 118393
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia
v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:1b80 class-ID: 0300
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 046d:0825
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
Screen-1: 0 s-res: 3840x1200 s-dpi: 93 s-size: 1049x321mm (41.30x12.64")
s-diag: 1097mm (43.19")
Monitor-1: DVI-D-0 pos: primary,right res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-2: HDMI-0 pos: left res: 1920x1200 hz: 60 dpi: 94
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX
1080/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
bus-ID: 09:00.1 chip-ID: 10de:10f0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: C-Media CM6631A Audio Processor
lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 0d8c:0004 class-ID: 0300
Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.5.4-zen2-1-zen status: kernel-api tools: N/A
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 168c:002b class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 3.41 TiB used: 187.95 GiB (5.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
fw-rev: H211011a temp: 43.9 C scheme: GPT
model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 96R9 scheme: GPT
used: 187.95 GiB (39.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 43.8 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 371 Uptime: 0m wakeups: 0 Memory: total: 16 GiB
available: 15.53 GiB used: 3.14 GiB (20.2%) Init: systemd v: 254
pm: pacman pkgs: 1567 libs: 481 tools: octopi,paru,yay Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: wezterm-gui inxi: 3.3.29
System install date: 2023-08-06
Last full system update: 2023-09-24
