Hello,
A few days ago my main monitor began randomly disconnecting. When this happens the graphics card usage skyrockets. Unplugging and replugging my monitor fixes it temporarily, but the issue will happen again later. It also messes up my desktop icon layout, grouping them all up randomly at the top. My display settings also get messed up, like having the refresh-rate reset to 60Hz instead of 144Hz. My second monitor seems normal, but the window animations slow down immensely at the time the black screen happens.
I thought the culprit might be this program I had installed called Sunshine. It’s used to stream games on LAN. I uninstalled with the -Rns options, but the issue is still occurring. It doesn’t seem to matter whether I’m doing nothing or if I have some applications running.
I’ve tried updating Garuda. I’ve searched online but didn’t find anything that sounds similar. I even asked ChatGPT to no avail. Any tips would be greatly appreciated!
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c3d6a053-0f9d-4107-9b5d-3dd29d943f43 rw rootflags=subvol=@
quiet resume=UUID=c96087d6-76f8-4056-abc9-2c4ca85f7c1d loglevel=3
amdgpu.ppfeaturemask=0xffffffff ibt=off
Type: Desktop Mobo: ASRock model: X670E Steel Legend
Megatrends LLC. v: 1.21 date: 04/26/2023
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3435 high: 4841 min/max: 400/5050 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4840 2: 400 3: 4836
4: 400 5: 4753 6: 400 7: 4840 8: 4837 9: 400 10: 4806 11: 400 12: 4823
13: 4841 14: 4825 15: 4818 16: 4752 bogomips: 134152
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: XFX
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 18:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 30.0 C
Device-3: Linux Foundation EEM Gadget driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:6
chip-ID: 1d6b:0102 class-ID: 0102
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1733 s-dpi: 96 s-size: 1185x458mm (46.65x18.03")
s-diag: 1270mm (50.02")
Monitor-1: DP-1 pos: primary,top-left model: ROG XG279Q serial: <filter>
built: 2021 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: bottom-r model: Lenovo LEN LI2364d
serial: <filter> built: 2016 res: 1920x1080 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 16.0.6 DRM 3.57 6.7.6-zen1-1-zen) device-ID: 1002:744c
memory: 19.53 GiB unified: no
API: Vulkan v: 1.3.276 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 24.0.1-arch1.1 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 18:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 18:00.6
Device-4: Linux Foundation EEM Gadget driver: snd-usb-audio,uvcvideo
Device-5: Corsair VOID ELITE Wireless Gaming Dongle
lanes: 1 mode: 1.1 bus-ID: 3-7:3 chip-ID: 1b1c:0a51 class-ID: 0300
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api with: aoss
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 09:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
Device-3: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0a:00.0
IF: enp10s0 state: down mac: <filter>
Device-4: Microsoft Xbox 360 Wireless Adapter driver: N/A type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 045e:0719
class-ID: ff00 serial: <filter>
IF-ID-1: se-sto-wg-006 state: unknown speed: N/A duplex: N/A mac: N/A
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-12:5 chip-ID: 0e8d:0616
Report: btmgmt ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Local Storage: total: 4.55 TiB used: 1.35 TiB (29.7%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 26.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: 4B2QEXM7 temp: 25.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 897.69 GiB size: 897.69 GiB (100.00%)
used: 338.09 GiB (37.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 897.69 GiB size: 897.69 GiB (100.00%)
ID-4: /var/log raw-size: 897.69 GiB size: 897.69 GiB (100.00%)
ID-5: /var/tmp raw-size: 897.69 GiB size: 897.69 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.47 GiB used: 4 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.52 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 63.5 C mobo: 30.0 C
GPU: device: amdgpu temp: 35.0 C mem: 48.0 C fan: 0 watts: 22.00
device: amdgpu temp: 30.0 C
Memory: total: 32 GiB note: est. available: 30.47 GiB used: 9.33 GiB (30.6%)
Processes: 437 Power: uptime: 1d 19h 8m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2104 libs: 582 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-11-24
Last full system update: 2024-02-24
Failed units: NetworkManager-wait-online.service
