Display issue - multi-monitor + Nvidia
Hello again everybody finally made it back after much discord in life... I have an issue that after garuda-update my pretty fairly well 4-Head/Monitor system all went black & grey... I looked for paru-nvidia but do not see this ---> listed? Linux, Solaris, and FreeBSD driver 520.56.06 [new feature branch release] - Announcements and News - NVIDIA Developer Forums Here is my inxi-Faz .....
.%;888:8898898:               ---------------------------------------
x;XxXB%89b8:b8%b88:             OS: Garuda Linux
.8Xxd                8X:.          Host: ASUSTeK COMPUTER INC. ROG STRIX B550-F GAMING
.8Xx;                    8x:.        Kernel: 5.19.13-zen1-1-zen
.tt8x          .d            x88;      Uptime: 10 hours, 41 mins
.@8x8;          .db:              xx@;    Packages: 1710 (pacman), 11 (flatpak)
,tSXX°          .bbbbbbbbbbbbbbbbbbbB8x@;   Shell: bash
.SXxx            bBBBBBBBBBBBBBBBBBBBbSBX8;   DE: Plasma 5.25.5
,888S                                     pd!   WM: KWin
8X88/                                       q    Terminal: konsole
GBB.                                             CPU: AMD Ryzen 7 5700G with Radeon Graphics (16) @ 3.8GHz
x%88        d888@8@X@X@X88X@@XX@@X@8@X.         GPU: AMD ATI Cezanne
dxXd    dB8b8b8B8B08bB88b998888b88x.          GPU: NVIDIA GeForce GTX 960
dxx8o                      .@@;.             Memory: 3.14GiB / 30.65GiB
dx88                   .t@x.
d:SS@8ba89aa67a853Sxxad.
.d988999889889899dd.
lightsight@lightsight in ~
λ inxi -Faz
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=ffd2cbda-1b3f-469b-b162-600ad680d696 rw rootflags=subvol=@
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
M705 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7
(7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2098 high: 3800 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2994 2: 2994
3: 1400 4: 1400 5: 1400 6: 3327 7: 1400 8: 2496 9: 1400 10: 3800 11: 1400
12: 1400 13: 1400 14: 2968 15: 2395 16: 1400 bogomips: 121370
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: eVga.com. driver: nvidia
v: 470.141.03 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max: lanes: 16
bus-ID: 03:00.0 chip-ID: 10de:1401 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
active: HDMI-A-1 empty: DP-1 bus-ID: 08:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 32.0 C
compositor: kwin_x11 driver: X: loaded: nvidia gpu: amdgpu display-ID: :0
Screen-1: 0 s-res: 3600x1080 s-dpi: 305 s-size: 300x90mm (11.81x3.54")
s-diag: 313mm (12.33")
Monitor-1: DVI-D-0 pos: bottom-r res: 1680x1050 hz: 60 dpi: 99
size: 433x270mm (17.05x10.63") diag: 510mm (20.09") modes: N/A
Monitor-2: HDMI-0 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA
470.141.03 direct render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1
link-max: lanes: 16 bus-ID: 03:00.1 chip-ID: 10de:0fba class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
Local Storage: total: 3.64 TiB used: 1.71 TiB (46.9%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 type: SSD serial: <filter> rev: P7CR402 temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 type: SSD serial: <filter> rev: P7CR402 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.71 TiB (93.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
(0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.71 TiB
(93.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.71 TiB
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.71 TiB
ID-1: swap-1 type: zram size: 30.65 GiB used: 832 MiB (2.7%)
System Temperatures: cpu: 38.0 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 62 C fan: 5% device: amdgpu
temp: 33.0 C
Processes: 340 Uptime: 10h 41m wakeups: 14 Memory: 30.65 GiB used: 3.14 GiB
(10.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1721 pm: pacman pkgs: 1710
libs: 447 tools: octopi,pamac,paru,yay pm: flatpak pkgs: 11 Shell: fish
v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
Only the very first restore/timeshift point works to get me here after , so i seem to have exhausted the possibilities on arch wiki and youtube/odysee , etc... I apologize if this is an obvious issue i do not yet understand.... I also very much would prefer to use my still in box xfx 5700 XT Radeon but a previous Programmer that i have very much to thank for even being here at all could not even figure out how to get it to work on this system i built myself.... Cannot thank you all enough for your wisdom, knowledge, kind compassion and selfless ;Dedication... Namaste, Light <3
youtube & all the other sites are working again with sound after a quick refresh of "Brave" browser but the other two monitors won't consistently stay on other than at bootup/login/display icon of "ASUS" & or Grub/Timeshift, etc... but it goes off and neither of the other two heads/monitors will not be detected by sudo nvidia-settings - - - x configuration
λ sudo nvidia-settings
[sudo] password for lightsight:
** (nvidia-settings:45977): WARNING **: 00:30:20.398: Unable to connect to dbus: Error spawning command line “
dbus-launch --autolaunch=f54235d1796a46bda940974129c64fae --binary-syntax --close-stderr”: Child process exite
d with code 1
(nvidia-settings:45977): GLib-GObject-CRITICAL **: 00:30:20.407: g_object_unref: assertion 'G_IS_OBJECT (objec
t)' failed
(nvidia-settings:45977): GLib-GIO-CRITICAL **: 00:30:20.524: g_dbus_connection_register_object: assertion 'G_I
S_DBUS_CONNECTION (connection)' failed
(nvidia-settings:45977): GLib-GIO-CRITICAL **: 00:30:20.524: g_dbus_connection_get_unique_name: assertion 'G_I
(nvidia-settings:45977): GLib-GIO-CRITICAL **: 00:30:48.496: g_dbus_connection_register_object: assertion 'G_I
(nvidia-settings:45977): GLib-GIO-CRITICAL **: 00:30:48.496: g_dbus_connection_get_unique_name: assertion 'G_I
