Manny
10 November 2020 01:10
1
Hello everyone I just installed Garuda and I am having some issues with display. With the following images I can explain my problem.
So I have an image with Hardware Acceleration turned on.
As you can see, Blues and maybe the others as well look kinda off. You can tell in the blues for sure tho. The color looks more like a purple then a blue. Not sure what to do to fix that problem. Will appreciate any help and thanks in advance
here are my system info
OS: Garuda Linux x86_64
Host: HP Pavilion 15 Notebo
Kernel: 5.9.6-zen1-1-zen
Uptime: 38 mins
Packages: 1917 (pacman)
Shell: zsh 5.8
Resolution: 1366x768
DE: Plasma 5.20.2
WM: KWin
WM Theme: WhiteSur-dark
Theme: WhiteSurDark [Plasma
Icons: Tela-circle-dark [Pl
Terminal: konsole
Terminal Font: Source Code
CPU: Intel i3-4005U (4) @ 1
GPU: Intel Haswell-ULT Memory: 2841MiB / 15939MiB ```
I think it has to do with hardware acceleration but not sure. Only saying that cause when I disable hardware acceleration it looks fine. But then again its on the whole system and I kinda need the hardware acceleration cause there is a certain game that lags terribly without it
SGS
10 November 2020 02:24
2
How you make this picture?
More details in
inxi -Fxxxza
and
Manny
10 November 2020 02:29
3
The picture I took it by just using the normal screenshot tool(spectacle). I did take another picture without using hardware acceleration.
system info
Kernel: 5.9.6-zen1-1-zen x86_64 bits: 64 compiler: N/A
root=UUID=9b8a9717-42ef-49b2-824c-9523f971ffc4 rw [email protected] quiet
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 0896100000304100000620100 serial: <filter> Chassis: type: 10
Mobo: Hewlett-Packard model: 2163 v: 29.42 serial: <filter> UEFI: Insyde
v: F.72 date: 03/09/2018
ID-1: BAT0 charge: 23.7 Wh condition: 23.7/23.7 Wh (100%) volts: 16.9/14.8
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full
Info: Dual Core model: Intel Core i3-4005U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 13569
Speed: 1596 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 1596 2: 1596
3: 1596 4: 1584
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: Suyin HP Truevision HD type: USB driver: uvcvideo bus ID: 2-3:3
chip ID: 064e:e264 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.2.1 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.9.6-zen1-1-zen
Device-1: Realtek RTL8188EE Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8188ee v: kernel port: 4000
bus ID: 08:00.0 chip ID: 10ec:8179
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 09:00.0
chip ID: 10ec:8136
Local Storage: total: 698.64 GiB used: 25.64 GiB (3.7%)
ID-1: /dev/sda vendor: Western Digital model: WD7500BPVX-60JC3T0
size: 698.64 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw size: 187.73 GiB size: 187.73 GiB (100.00%)
used: 25.61 GiB (13.6%) fs: btrfs dev: /dev/sda6
ID-2: /home raw size: 187.73 GiB size: 187.73 GiB (100.00%)
ID-3: /var/log raw size: 187.73 GiB size: 187.73 GiB (100.00%)
ID-4: /var/tmp raw size: 187.73 GiB size: 187.73 GiB (100.00%)
ID-1: swap-1 type: zram size: 996.2 MiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 996.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 996.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 996.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 274 Uptime: 2h 06m Memory: 15.57 GiB used: 3.37 GiB (21.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1917 lib: 559 flatpak: 0 snap: 0 Shell: Zsh v: 5.8
running in: konsole inxi: 3.1.06```
Also thank heard about you guys thru Tylerś Tech youtube.
SGS
10 November 2020 02:38
4
Thank you, because I never had a problem with it and I don't use an HP Notebook I have to pass.
I am almost sure that you can still be helped here.
What did your search on the internet show regarding this problem?
Manny
10 November 2020 02:45
5
Well I do distro hop a lot and kinda got my problem fixed with some kind of RGB setting using terminal. Not sure what the command was.I've tried Pop Os, Mx Linux,Linux Mint, Fereon Os, Manjaro, KDE Neon, Ubuntu, Fedora and this one of course. The only 2 that hasn't given me problems is Linux Mint and Manjaro. But heard about this distro and wanted to try it out. And it was fine when I ran it thru the USB but I have noticed that with the new updates that's when it starts messing up.
tbg
10 November 2020 03:38
6
I would test the linux-lts kernel then. Be sure to install the linux-lts-headers as well.
Manny
10 November 2020 03:55
7
How do we do the headers?
Manny
10 November 2020 04:27
9
I tried the Lts kernel and that didn't fix my problem @SGS I mean that's the only problem I have I think. Just the colors.
Naman
10 November 2020 04:53
10
You can change and adjust colors in kde settings.
Manny
14 November 2020 22:50
11
So going into System settings> Color Corrections> add profile> and choosing from the already installed ones, I chose "Apple RGB" and that for the most part fixed my problem.
