Hello everyone!
I'm having a little issue with the size of some elements on display:
I use garuda dragonized gaming edition. As you can see in the screenshot, the top bar and the icon bar at the bottom are way smaller than what you'd expect them... The same is true for the application menu, it's not even half screen
I have a 3840x2160 monitor, I'm not using dual monitors. I've tried to set the scale under the monitor settings but it's affecting only font scaling for menus and applications.
While there was still latte dock the bottom icons bar was bigger.
Any idea or suggestion for what I could try to fix this issue?
Thanks in advance!
Kernel: 6.2.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=1b38e87f-3760-49b3-866d-731b5f0b0a33 rw rootflags=subvol=@
quiet
cryptdevice=UUID=9074fab6-463a-46ea-a0e4-f3e75f597eae:luks-9074fab6-463a-46ea-a0e4-f3e75f597eae
root=/dev/mapper/luks-9074fab6-463a-46ea-a0e4-f3e75f597eae quiet splash
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING WIFI II
v: Rev X.0x serial: <superuser required> UEFI: American Megatrends v: 0309
date: 08/16/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3815 high: 4353 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3694 4: 3800 5: 3593 6: 3777 7: 3794 8: 3800 9: 3800 10: 3800 11: 3800
12: 3839 13: 3800 14: 3800 15: 4353 16: 3800 bogomips: 121371
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 525.xx+ status: current (as of 2023-02) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
empty: DP-2,DP-3,HDMI-A-2 bus-ID: 09:00.0 chip-ID: 10de:2208
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1015x571mm (39.96x22.48")
s-diag: 1165mm (45.85")
Monitor-1: DP-1 pos: primary model: Samsung U28H75x serial: <filter>
built: 2018 res: 3840x2160 hz: 60 dpi: 161 gamma: 1.2
size: 607x345mm (23.9x13.58") diag: 698mm (27.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-1 model: Samsung built: 2014
res: 1920x1080 hz: 60 dpi: 55 gamma: 1.2 size: 885x498mm (34.84x19.61")
diag: 801mm (31.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.5 Mesa 22.3.6 renderer: llvmpipe (LLVM 15.0.7 256 bits)
direct-render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
bus-ID: 09:00.1 chip-ID: 10de:1aef class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.2.6-zen1-1-zen running: yes
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0608
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-6:5 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 0 state: down
bt-service: disabled rfk-block: hardware: no software: no address: N/A
Local Storage: total: 5.74 TiB used: 103.26 GiB (1.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 250GB
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
ID-5: /dev/sde maj-min: 8:64 type: USB model: USB Disk 3.0 size: 57.99 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 8.01 scheme: GPT
ID-1: / raw-size: 57.68 GiB size: 57.68 GiB (100.00%)
used: 41.05 GiB (71.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-9074fab6-463a-46ea-a0e4-f3e75f597eae
used: 752 KiB (0.2%) fs: vfat dev: /dev/sde1 maj-min: 8:65
ID-3: /home raw-size: 57.68 GiB size: 57.68 GiB (100.00%)
ID-4: /var/log raw-size: 57.68 GiB size: 57.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 57.68 GiB size: 57.68 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.71 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 36.0 C mobo: 28.0 C
Processes: 318 Uptime: 9m wakeups: 0 Memory: 62.71 GiB used: 3.34 GiB (5.3%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1996 libs: 561
tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-12-31
Last full system update: 2023-03-16
