If anybody had a bit of knowlege about this, i was wondering how display configuration works, when i changed it in GUI it would reset after a reboot. i fixed it by adding an xrandr command under "DisplayCommand=" in the /etc/sddm.conf file.
so...
-from what i can tell sddm.conf controls display config on reboot
-But I also need to change it in "display settings" using GUI or else when "screen energy saving" kicks in it reverts to whatever the GUI "display settings" is set to and not sddm.conf
Question 1
What settings/file am i changing with the GUI and how do i do it via terminal
Question 2
is there a single file i can modify or command i can use to change display config globally
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=5ee75985-2241-465d-afdf-55aaf7e202a1 rw rootflags=subvol=@
amdgpu.freesync_video=1 quiet quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop System: Gigabyte product: X570 AORUS ELITE WIFI v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE WIFI v: x.x
serial: <superuser required> UEFI: American Megatrends v: F11
date: 12/06/2019
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3801 high: 4045 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3596 2: 3623
3: 3433 4: 3900 5: 3588 6: 3535 7: 3900 8: 3900 9: 3900 10: 3900 11: 3900
12: 3900 13: 3900 14: 3900 15: 3900 16: 4045 bogomips: 124564
protection
Device-1: AMD Hawaii XT / Grenada [Radeon R9 290X/390X]
vendor: Micro-Star MSI driver: amdgpu v: kernel alternate: radeon
arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17
pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1, DVI-D-1,
DVI-D-2, HDMI-A-1 empty: none bus-ID: 08:00.0 chip-ID: 1002:67b0
class-ID: 0300 temp: 64.0 C
Screen-1: 0 s-res: 6400x1572 s-dpi: 96 s-size: 1689x414mm (66.50x16.30")
s-diag: 1739mm (68.46")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: bottom-l model: HP 24es
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
Monitor-2: DVI-D-2 mapped: DVI-D-1 pos: bottom-r model: Samsung
built: 2013 res: 1920x1080 hz: 60 dpi: 55 gamma: 1.2
size: 886x498mm (34.88x19.61") diag: 1168mm (46") ratio: 16:9 modes:
Monitor-3: DP-1 mapped: DisplayPort-0 pos: primary,top-center
model: Gigabyte G32QC serial: <filter> built: 2020 res: 2560x1440 dpi: 93
gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
modes: max: 2560x1440 min: 640x480
Monitor-4: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r model: HP 24es
OpenGL: renderer: AMD Radeon R9 390 Series (hawaii LLVM 14.0.6 DRM 3.48
6.0.6-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
vendor: Micro-Star MSI driver: snd_hda_intel bus-ID: 1-2:2 v: kernel
chip-ID: 1b3f:2008 pcie: gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16
bus-ID: 08:00.1 chip-ID: 1002:aac8 class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Generalplus USB Audio Device type: USB
Device-4: Generalplus USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:5 chip-ID: 1b3f:2008
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-5:2 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 7.28 TiB used: 4.44 TiB (61.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
model: WD3003FZEX-00Z4SA0 size: 2.73 TiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD20EZRZ-22Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital model: WD
My Passport 0827 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1012 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 352.75 GiB
(75.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
(0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 352.75
GiB (75.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 352.75
ID-5: /var/tmp raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 352.75
ID-1: swap-1 type: zram size: 31.29 GiB used: 1.2 MiB (0.0%)
System Temperatures: cpu: 51.1 C mobo: 29.0 C gpu: amdgpu temp: 64.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 815
Processes: 403 Uptime: 3h 34m wakeups: 0 Memory: 31.29 GiB used: 5.63 GiB
(18.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2207
libs: 588 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.9-1):
System install date: 2022-04-06
Last full system update: 2022-11-03
