Hi all, my laptom has two dds:
on first one I've created /boot/efi + root
on second hard disk I've created /home
file system btrf
It's normal that in btrfs-assistant I don't see subvolume home?
this is just for know if all is ok
Rgs.
Rob.
file system btrf
Rgs.
Rob.
Missing garuda-inxi
Do you use Garuda Linux?
Why you post a picture?
sudo btrfs subvolume list /
lsblk
If you change the defaults, you should know why @home doesn't appear, right?
Thank you for your reply
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ebebbf38-3a1b-453b-b0f4-2ecd10e72e70
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0 Distro: Garuda Linux
Type: Laptop System: ASUSTeK product: GL753VD v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: GL753VD v: 1.0 serial: <superuser required> UEFI: American Megatrends
v: GL753VD.308 date: 04/29/2019
ID-1: BAT0 charge: 34.3 Wh (99.4%) condition: 34.5/48.2 Wh (71.6%) volts: 16.2 min: 14.4
model: Simplo SDI ICR18650 type: Li-ion serial: <filter> status: not charging cycles: 33
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/M235 serial: <filter> charge: 5%
(should be ignored) rechargeable: yes status: discharging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake gen: core 7 built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xF0
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB desc: d-4x32
KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1550 high: 1600 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 1600 2: 1200 3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600
bogomips: 44798
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK driver: nouveau v: kernel
non-free: 515.xx+ status: current (as of 2022-07) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 1-11:5
chip-ID: 13d3:5666 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 compositor: gnome-shell driver:
X: loaded: modesetting,nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x04e8 built: 2015 res: 1920x1080 hz: 60 dpi: 128
gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
Device-1: Intel CM238 HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
Device-2: Realtek RTL8111/8168/8411
PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-9:4
chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.14 TiB used: 89.73 GiB (7.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: A020
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q
ID-1: / raw-size: 238.18 GiB size: 238.18 GiB (100.00%) used: 13.52 GiB (5.7%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 54.49 GiB (5.8%) fs: btrfs
dev: /dev/sdb1 maj-min: 8:17
ID-4: /var/log raw-size: 238.18 GiB size: 238.18 GiB (100.00%) used: 13.52 GiB (5.7%)
ID-5: /var/tmp raw-size: 238.18 GiB size: 238.18 GiB (100.00%) used: 13.52 GiB (5.7%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 50.0 C pch: 52.0 C mobo: N/A gpu: nouveau temp: 42.0 C
Fan Speeds (RPM): cpu: 2000
Processes: 326 Uptime: 3h 2m wakeups: 9 Memory: 15.51 GiB used: 3.68 GiB (23.7%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: 1459 pacman: 1438
lib: 376 flatpak: 21 Client: shell wrapper v: 5.1.16-release inxi: 3.3.20
Garuda (2.6.7-1):
System install date: 2022-09-11
Last full system update: 2022-09-11
[sudo] password di robertocannito:
ID 256 gen 695 top level 5 path @
ID 257 gen 506 top level 5 path @root
ID 258 gen 36 top level 5 path @srv
ID 259 gen 693 top level 5 path @cache
ID 260 gen 691 top level 5 path @log
ID 261 gen 695 top level 5 path @tmp
ID 262 gen 526 top level 256 path .snapshots
ID 295 gen 462 top level 262 path .snapshots/33/snapshot
ID 296 gen 463 top level 262 path .snapshots/34/snapshot
ID 297 gen 466 top level 262 path .snapshots/35/snapshot
ID 298 gen 467 top level 262 path .snapshots/36/snapshot
ID 299 gen 475 top level 262 path .snapshots/37/snapshot
ID 300 gen 476 top level 262 path .snapshots/38/snapshot
ID 301 gen 482 top level 262 path .snapshots/39/snapshot
ID 302 gen 483 top level 262 path .snapshots/40/snapshot
ID 303 gen 492 top level 262 path .snapshots/41/snapshot
ID 304 gen 493 top level 262 path .snapshots/42/snapshot
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 238,5G 0 disk
├─sda1 8:1 0 300M 0 part /boot/efi
└─sda2 8:2 0 238,2G 0 part /var/cache
sdb 8:16 0 931,5G 0 disk
└─sdb1 8:17 0 931,5G 0 part /home
sr0 11:0 1 1024M 0 rom
zram0 254:0 0 15,5G 0 disk [SWAP]
Sincerly I didn’t know, I’m new to Garuda, is this necessary or is ok?
Eventually is this a problem and how I can fix it?
Must I create also a config for home with:
snapper -c home create-config /home
Creating subvolumes on specific directories is made in order to prevent them from being snapshotted. If /home is on a seperate partition, it will not be a part of the OS partition so creating a /home subvolume will be unnecessary.
Usually this is not necessary.
So what do you suggest?
Could you tell me step by step what I must do?
With /home
on a separate disk, I believe this is correct and I think you will have to create a subvolume for it first as well since it is a different partition.
The step-by-step guide is here: Snapper - ArchWiki
I'm not able to create subvolume on hdb, there's an already partition and I think that I've made a big trouble, I don't know what I've made but hdb has been fused with hda... ish..
force to use gparder from live distro for create again the two disks..
I don't know how to do, if somebody may explaine me and follow me step by step this should be great.. otherwise never mind
if easy also starting from a new installation
Well… from your inxi:
Is it very neccessary for you to have your /home on the bigger ssd?
Otherwise you could just reinstall including /home in your sda and the “problem” is gone.
Then again: Why is it a problem in general? Is it very neccessary for you to be able to use snapper on your /home partition? Because usually it’s used to set the system back after fucking up and /home usually does not get fucked up… ever.
Where exactly do you think you have made an error?
If this is still a question for you I’d answer it - again, as others already did - with no, and suggest moving on.
If you’re unwilling to move on from it, use the link @BluishHumility gave and put in the work.
Whatever you are attempting to communicate here is unclear. If your disk layout has changed, explain what happened and show:
lsblk -f
and
sudo parted -l
