I have recently installed the Dragonized version then I went and changed the way the updates are applied by setting them to update software automatically and checked the "use offline updates" box.
Since then, even though I have reverted back to manual updates and unchecked the "use offline updates" check box Discover is stuck on asking me to restart each time I log in.
Is there a way, besides ignoring the message, to get it out of the loop?
I was not pointing fingers at Garuda. There is no need to get so defensive.
I was reporting that there is a problem within the OS (regardless of whether it is related to the work done by the Garuda team or not). Pretty much as with the updater not opening for which you do have a header with a fix, here.
Am I not supposed to ask for advice and guidance within the very forums of the OS?
Apart from the fact that I → ← were joking, I feel you were attacking
Garuda as the culprit just because it comes with the DE. So, sorry if I have misunderstood.
I wanted to point out that when you report mistakes, you should also write the correct names. Here it was easy but there are also users who think,
the “updater” or Add/Remove Software,
pacman and pamac are the same. And both are not from Garuda.
Correct. Mea culpa for typing it wrong and thanks @SameExpert for mediating
I will know better for the future that typing mistakes are not tolerated on these forums nor reporting wrong functionality for apps that are not created by Garuda.
Hi Brother, Knowledge is Knowledge as it is Shared Otherwise, It Will Become a Secret, We Will Learn When It Comes, We Will Teach When It Comes, Thank you for your understanding
@Bro Thank you for the suggestion! I confirm as well; uninstalling packagekit-qt5 and reinstall it didn’t work for me either. I just uninstalled it and will manually run Discover from time to time thus removing the tray notifier.
@SameExpert does octopi-dev have a tray notifier as well? I’ve installed it but didn’t seem to have one. Later edit
Found it.
Cose I'm lazy and I like my systems to do the work for me
While I am at it and to alleviate any and all bad water that might have accumulated under the bridge, I do want to say that I like the Garuda Dragonized Gaming edition a lot. I do believe you guys have done a great work with it and will start supporting it the best I can, including financially.
