Attempting to play Helldivers 2 with voice chat, my microphone is detected by the game itself but not on discord. For some reason, My PS5’s controller microphone will work when that’s plugged in, but not my actual headset.
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=3e56dd2d-916f-4822-9f3d-d9762a8c38d9 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MAG X570S TOMAHAWK MAX WIFI (MS-7D54)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.00 date: 07/06/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3830 high: 4402 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 4101
3: 3800 4: 3800 5: 3800 6: 3879 7: 3884 8: 3598 9: 3608 10: 3800 11: 3727
12: 4402 13: 3749 14: 3696 15: 3849 16: 3800 bogomips: 121598
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: ASUSTeK driver: nvidia
(as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,HDMI-A-2 empty: DP-1,DP-3,HDMI-A-1
bus-ID: 2d:00.0 chip-ID: 10de:2482 class-ID: 0300
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: DP-2 note: disabled pos: primary,left model: ES-27G2
serial: <filter> built: 2022 res: 1920x1080 dpi: 70 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 687mm (27.1") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-2 mapped: HDMI-1 note: disabled pos: right
model: Dell S2409W serial: <filter> built: 2009 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.276 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2482
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 2d:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 0db0:a073 class-ID: 0300
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 28:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0032
Local Storage: total: 4.78 TiB used: 1.02 TiB (21.3%)
fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST750LM022 HN-M750MBB
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: MBR
used: 353.95 GiB (76.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 77.5 MiB (0.2%)
System Temperatures: cpu: 44.5 C mobo: N/A gpu: nvidia temp: 51 C
Memory: total: 32 GiB available: 31.26 GiB used: 7.19 GiB (23.0%)
Processes: 404 Power: uptime: 1h 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1867 libs: 566 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-12-15
Last full system update: 2024-02-19
