This is something that I am quite confused about - I can only seem to reproduce this with Minecraft and Discord (community/discord
Steps on how I get it to produce this behavior every time:
1. start minecraft
2. start discord
3. join a voice channel
4. tab to minecraft and click something, then tab back to discord
5. leave the voice channel and join again
After this my sound is gone (sometimes even already after leaving the channel).
With sound I mean notification sounds (calls, messages, channel join / leaves, disconnects, etc)
I am quite new to Arch-based distros and couldn't figure that one out on my own - so that is why I am asking here
╭─michi@michipc in ~ took 26ms
╰─λ inxi -Faz
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8a867051-e212-4c46-97f8-81134543f621 rw rootflags=subvol=@
Type: Desktop Mobo: MEDION model: Z97 GAMING 7 (MS-7916) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: M7916W0X.203
date: 08/06/2015
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4390 high: 4401 min/max: 800/4400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 4400 2: 4400 3: 4400
4: 4400 5: 4401 6: 4359 7: 4372 8: 4392 bogomips: 63997
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0412 class-ID: 0300
Device-2: NVIDIA GM200 [GeForce GTX TITAN X] driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:17c2
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-9.4:10 chip-ID: 046d:082d
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.0x11.2")
s-diag: 1550mm (61")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 90
size: 543x302mm (21.4x11.9") diag: 621mm (24.5")
Monitor-3: DP-4 res: 1920x1080 dpi: 90 size: 544x303mm (21.4x11.9")
diag: 623mm (24.5")
OpenGL: renderer: NVIDIA GeForce GTX TITAN X/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-3: NVIDIA GM200 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 02:00.1 chip-ID: 10de:0fb0 class-ID: 0403
Device-4: Kingston HyperX Cloud Flight S type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:2 chip-ID: 0951:16ea
Device-5: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: c000 bus-ID: 05:00.0
chip-ID: 1969:e091 class-ID: 0200
IF-ID-1: cni-podman0 state: down mac: <filter>
IF-ID-3: wlp0s20u5i2 state: down mac: <filter>
Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB
driver: btusb,rtl8xxxu bus-ID: 3-5:4 chip-ID: 0bda:b720 class-ID: e001
Local Storage: total: 4.08 TiB used: 1.57 TiB (38.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SHSS37A480G
type: SSD serial: <filter> rev: 00.r scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM000-1F2168
type: HDD rpm: 5900 serial: <filter> rev: CC54 scheme: GPT
used: 69.66 GiB (15.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 31.25 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 72 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 318 Uptime: 5h 39m wakeups: 0 Memory: 31.26 GiB
used: 7.74 GiB (24.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1767 lib: 474 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
Also not leaving stuff out:
I changed my audio setup to run on pipewire:
╭─michi@michipc in ~ took 1s
╰─λ pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 146
Tile Size: 65472
User Name: michi
Host Name: michipc
Server Name: PulseAudio (on PipeWire 0.3.42)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.usb-Kingston_HyperX_Cloud_Flight_S_000000000001-00.analog-stereo
Default Source: alsa_input.usb-Kingston_HyperX_Cloud_Flight_S_000000000001-00.mono-fallback
Cookie: a6e8:8491
Hope someone is able to help me because this is really annoying to be honest. Thanks and merry christmas
