Hello Garuda users.
Problem:
(With discord I mean "community/discord")
When I join a voice channel in discord I can normally hear other users. After a seemingly random time I suddenly cant hear others anymore.
The discord sounds work fine (like I hear when somebody joins or leaves the channel) and I even have the green circles around the user profile pictures that indicate that they are speaking. But I cannot hear them.
I need to leave the voice channel and reconnect and everything works fine again.
Sometimes this happens randomly, but sometimes seems to be connected to starting a game or pressing a button in a game. But nothing consistent.
Here is the output of my sudo garuda-inxi (hope that I wasnt wrong to run it as sudo):
Kernel: 6.1.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=26328002-0c7a-4fb4-9ce6-c8779c8104d4 rw [email protected]
resume=UUID=5d6c4dd7-faab-4ef7-b148-fd8c145df549 loglevel=3
hibernate=nocompress amdgpu.aspm=0 amdgpu.dc=1 amdgpu.vm_update_mode=0
amdgpu.dpm=-1 amdgpu.ppfeaturemask=0xffffffff amdgpu.vm_fault_stop=2
amdgpu.vm_debug=1 amdgpu.gpu_recovery=0 ibt=off
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450 Gaming-ITX/ac serial: <filter>
UEFI: American Megatrends v: P5.10 date: 10/20/2022
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3400 min/max: 1550/3400 boost: enabled
base/boost: 3400/3900 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3400 2: 3400 3: 3400 4: 3400
5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
bogomips: 81593
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: Micro-Star MSI
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0c:00.0 chip-ID: 1002:687f
Device-2: KYE Systems (Mouse Systems) PC-LM1E Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.1.4:8 chip-ID: 0458:6006
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (19.96x12.48")
s-diag: 598mm (23.54")
Monitor-1: DP-1 mapped: DisplayPort-0 model: EIZO NANAO SX2461W
serial: <filter> built: 2008 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 519x324mm (20.43x12.76") diag: 616mm (24.2") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon RX Vega (vega10 LLVM
14.0.6 DRM 3.49 6.1.5-zen2-1-zen) direct render: Yes
Device-1: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel bus-ID: 1-10:5 pcie: chip-ID: 0d8c:0134 gen: 3 speed: 8 GT/s
class-ID: 0300 lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:aaf8 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0e:00.3
Device-3: C-Media Anua Mic CM 900 type: USB
Device-4: KYE Systems (Mouse Systems) PC-LM1E Camera type: USB
Sound API: ALSA v: k6.1.5-zen2-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
IF-ID-1: enp2s0f0u1c4i2 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:3
chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 5.52 TiB used: 3.36 TiB (60.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 12d 8h cycles: 843
read-units: 92,303,360 [47.2 TB] written-units: 42,972,986 [22.0 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWL120
family: L200 (SMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 0A temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 362d 19h cycles: 3802
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
family: Micron Client SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 023 temp: 45 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 29d 4h cycles: 1784
written: 26.71 TiB
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Hitachi
model: HUP722020APA330 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: JKAOA36C temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6y 17d 8h cycles: 415
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Generic
model: MassStorageClass size: 59.63 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1209 scheme: MBR
ID-1: / raw-size: 899.22 GiB size: 899.22 GiB (100.00%)
used: 775.98 GiB (86.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 14.3 MiB (4.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 899.22 GiB size: 899.22 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 899.22 GiB size: 899.22 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 899.22 GiB size: 899.22 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 4.28 GiB (13.7%)
ID-2: swap-2 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 56.9 C mobo: N/A gpu: amdgpu temp: 48.0 C
mem: 48.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1039 fan-3: 944 fan-4: 0 fan-5: 0
gpu: amdgpu fan: 637
Processes: 442 Uptime: 17h 32m wakeups: 2 Memory: 31.27 GiB
used: 10.14 GiB (32.4%) Init: systemd v: 252 default: graphical
pkgs: 1962 libs: 550 tools: octopi,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-11-13
Last full system update: 2023-01-16 ↻
Windows dual boot: Yes
I already searched the web for 1-2 hours the past days but couldnt find any solutions. If I missed something, I am sorry.
What I tried so far:
- Updating the system (happens for quite a while now)
- Using Discord Canary (Same problem after a while, worked fine for longer than normal discord)
- Using Discord Arch Electron (Same as Discord Canary)
Because I have no more ideas I wanted to ask here, if somebody has any other ideas I could try.
Please let me know if there is anything I can do better for this or any future topics. Thanks!
