Disappearing Taskbar
I am a Garuda Mokka user. I have an external monitor, and I have kept it as my primary monitor.
When I remove hdmi connection, the task bar suddenly disappears and I am unable to see the task bar, when I connect it back, it is visible on the secondary monitor(which is my built-in monitor).
I have tried to change the primary monitor to my built-in monitor and still the issue pertains.
Help me out
here is my garuda inxi:
inxi -Faz
Kernel: 6.16.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=38aa7a8a-9ffc-4228-bb02-80689bb55c20 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Laptop System: LENOVO product: 20H1004UIG v: ThinkPad E470
Mobo: LENOVO model: 20H1004UIG serial: <superuser required>
part-nu: LENOVO_MT_20H1_BU_Think_FM_ThinkPad E470 uuid: <superuser required>
UEFI: LENOVO v: R0DETA6W (2.06 ) date: 01/27/2022
ID-1: BAT0 charge: 12.5 Wh (74.9%) condition: 16.7/45.0 Wh (37.1%)
power: 9.8 W volts: 12.3 min: 10.9 model: SANYO 01AV411 type: Li-ion
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF6
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3101 min/max: 400/3100 scaling: driver: intel_pstate
governor: powersave cores: 1: 3101 2: 3101 3: 3101 4: 3101 bogomips: 21599
Type: gather_data_sampling mitigation: Microcode
Type: ghostwrite status: Not affected
Type: indirect_target_selection status: Not affected
Type: itlb_multihit status: KVM: Split huge pages
vulnerable
Type: old_microcode status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Not affected
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: conditional;
RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: tsa status: Not affected
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 04f2:b5c0
compositor: kwin_wayland driver: gpu: i915 d-rect: 3286x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: Samsung LS22D300G
serial: <filter> built: 2024 res: mode: 1920x1080 hz: 100 scale: 100% (1)
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
Monitor-2: eDP-1 pos: right model: BOE Display 0x06b3 built: 2015 res:
mode: 1366x768 hz: 60 scale: 100% (1) dpi: 112 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1366x768
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 15.15 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 25.2.1-arch1.2
device-ID: 8086:5916 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.1-arch1.2 (LLVM
API: ALSA v: k6.16.2-zen1-1-zen status: kernel-api tools: N/A
port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0cf3:e500
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: N/A
Local Storage: total: 2.75 TiB used: 44.17 GiB (1.6%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SU02G
size: 1.84 GiB block-size: physical: 512 B logical: 512 B type: Removable
tech: SSD serial: <filter>
ID-2: /dev/sda maj-min: 8:0 vendor: AARVEX model: AARQ1024GS072622030
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: BUP Ultra Touch
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0004 scheme: MBR
ID-1: / raw-size: 453.87 GiB size: 453.87 GiB (100.00%)
used: 44.17 GiB (9.7%) fs: btrfs dev: /dev/sda11 maj-min: 8:11
used: 49.4 MiB (51.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 453.87 GiB size: 453.87 GiB (100.00%)
ID-4: /var/log raw-size: 453.87 GiB size: 453.87 GiB (100.00%)
ID-5: /var/tmp raw-size: 453.87 GiB size: 453.87 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C pch: 55.0 C mobo: N/A
Memory: total: 16 GiB available: 15.52 GiB used: 3.21 GiB (20.7%)
Processes: 239 Power: uptime: 5h 36m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1528 libs: 376 tools: octopi,paru Compilers:
gcc: 15.2.1 alt: 14 Shell: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
Reminder for you from template.
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
Here is my garuda-inxi:
Kernel: 6.16.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
quiet loglevel=3
ID-1: BAT0 charge: 3.7 Wh (22.3%) condition: 16.6/45.0 Wh (36.8%)
power: 15.0 W volts: 10.2 min: 10.9 model: SANYO 01AV411 type: Li-ion
microcode: 0xF6
Speed (MHz): avg: 3102 min/max: 400/3100 scaling: driver: intel_pstate
governor: powersave cores: 1: 3102 2: 3102 3: 3102 4: 3102 bogomips: 21599
modes: 1366x768
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.5
HD Graphics 620 (KBL GT2) driver: mesa intel v: 25.2.1-arch1.5
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.1-arch1.5 (LLVM
API: ALSA v: k6.16.4-zen1-1-zen status: kernel-api tools: N/A
Report: btmgmt ID: hci0 rfk-id: 4 state: up address: N/A
Local Storage: total: 2.75 TiB used: 818.17 GiB (29.0%)
used: 49.66 GiB (10.9%) fs: btrfs dev: /dev/sda11 maj-min: 8:11
System Temperatures: cpu: 55.0 C pch: 50.5 C mobo: N/A
Memory: total: 16 GiB available: 15.52 GiB used: 2.91 GiB (18.7%)
Processes: 218 Power: uptime: 5h 23m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
Packages: pm: pacman pkgs: 1560 libs: 384 tools: octopi,paru Compilers:
gcc: 15.2.1 alt: 14 Shell: Bash v: 5.3.3 default: fish v: 4.0.2
Garuda (2.8.2-2):
System install date:     2025-08-09
Last full system update: 2025-09-03
22/23 checks run in 1.48 seconds ⌛
Powered by garuda-health 🦅
Have you tried connecting the monitor with a display port cable instead?
I use a laptop and have no display cable. Also the monitor does not have a display port. Just the hdmi.
