I open two documents side-by-side. I select text on one document. Then I click on the second document and the selection in the first document is invisible until I click back on the first document.
How do I retain the visibility of the text selection in 1st document while interacting with second document?
I asked about it on LibreOffice forum and they said it's something related to window manager and OS, so I'm moving the question to this forum.
$ garuda-inxi
Kernel: 5.15.86-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4bc99fd1-6a7e-4096-8fca-ccd010a3944b rw [email protected]
loglevel=3 ibt=off
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
Type: Laptop System: Acer product: Aspire A315-56 v: V1.15
Mobo: IL model: Sleepy_IL v: V1.15 serial: <superuser required>
UEFI: Insyde v: 1.15 date: 07/13/2020
ID-1: BAT1 charge: 40.2 Wh (100.0%) condition: 40.2/47.8 Wh (84.1%)
volts: 12.2 min: 11.2 model: LGC AP18C8K type: Li-ion serial: N/A
status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB6
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1609 high: 2303 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2303 2: 1622 3: 1263
4: 1250 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 0408:a061 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: eDP-1 model: BOE Display 0x07cb built: 2018 res: 1920x1080
ratio: 16:9 modes: 1920x1080
missing.
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
Sound API: ALSA v: k5.15.86-1-lts running: yes
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-10:4 chip-ID: 04ca:3015 class-ID: e001
Local Storage: total: 238.47 GiB used: 147.76 GiB (62.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ1 size: 238.47 GiB block-size: physical: 512 B
rev: E8FK12.3 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
used: 147.76 GiB (62.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 594 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.56 GiB used: 578.4 MiB (7.5%)
System Temperatures: cpu: 70.0 C mobo: N/A
Processes: 259 Uptime: 1d 19h 26m wakeups: 24 Memory: 7.56 GiB
used: 2.15 GiB (28.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1639
pm: pacman pkgs: 1633 libs: 400 tools: paru pm: flatpak pkgs: 6 Shell: Bash
v: 5.1.16 running-in: qterminal inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-09-11
Last full system update: 2023-01-14 ↻
Relevant software: snapper(custom) NetworkManager mkinitcpio
Failed units: shadow.service
