I installed garuda-hyprland but the display setting does not work and I can’t use two monitors at the same time, can anyone help?
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Did you search in forum?
Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
in the body of the post (not linked externally, or collapsed with the “hide details” feature)
) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
And
You will probably have to manually manage them …
Configuring monitors
as done with the wiki
P.s garuda-inxi
, would make people helping you easier.
