I wanted to connect to a different router with wifi so I disconnected the ethernet with Network manager but after restarting I see Wired: cable unplugged
I am on a laptop (legion to be exact), I looked around but couldn't fix it.
Also, the output of ip link show dev enp7s0
2: enp7s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether 98:fa:9b:2d:52:11 brd ff:ff:ff:ff:ff:ff
When I try to activate the Wired connection 1 with nmtui I get `Could not activate connection: Connection 'Wired connection 1' is not availble on device enp7s0 because device has no carrier.
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=392bffd4-0fd1-42c4-a26e-95dc0ab8ab7b rw rootflags=subvol=@
Desktop: Cinnamon v: 5.6.1 tk: GTK v: 3.24.34 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81SX v: Legion Y540-15IRH
serial: <superuser required> Chassis: type: 10 v: Legion Y540-15IRH
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: BHCN45WW date: 05/24/2022
ID-1: BAT0 charge: 47.0 Wh (96.9%) condition: 48.5/57.0 Wh (85.1%)
volts: 12.8 min: 11.5 model: SMP L17M3PG2 type: Li-poly serial: <filter>
status: not charging cycles: 73
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2896 high: 4401 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 2600 2: 2600 3: 2600
4: 2600 5: 2600 6: 2600 7: 2600 8: 2600 9: 4401 10: 4354 11: 2600 12: 2600
bogomips: 62399
vulnerable
PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Lenovo
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:2191
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 5986:2113 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 143 s-size: 682x191mm (26.85x7.52")
s-diag: 708mm (27.88")
Monitor-1: DP-2 pos: right res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
Monitor-2: DP-3 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA TU116 High Definition Audio vendor: Lenovo
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-2: wg_admin state: unknown speed: N/A duplex: N/A mac: N/A
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.84 TiB used: 190.13 GiB (10.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNV1T02 KIOXIA size: 953.87 GiB block-size: physical: 512 B
rev: HP00AE00 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
type: HDD rpm: 5400 serial: <filter> rev: 1A04 scheme: GPT
ID-1: / raw-size: 495.08 GiB size: 495.08 GiB (100.00%)
used: 190.11 GiB (38.4%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 18 MiB (3.5%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 495.08 GiB size: 495.08 GiB (100.00%)
ID-4: /var/log raw-size: 495.08 GiB size: 495.08 GiB (100.00%)
ID-5: /var/tmp raw-size: 495.08 GiB size: 495.08 GiB (100.00%)
ID-1: swap-1 type: partition size: 4.42 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.53 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 72.0 C pch: 63.0 C mobo: N/A gpu: nvidia
temp: 56 C
Processes: 340 Uptime: 2m wakeups: 1 Memory: 15.53 GiB
used: 3.37 GiB (21.7%) Init: systemd v: 252 default: graphical
pkgs: 1658 libs: 454 tools: paru,yay pm: pkg pkgs: 0 Shell: fish v: 3.5.1
running-in: alacritty inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-10-06
Last full system update: 2022-11-20
Is partially upgraded: Yes
