Disable 2nd Monitor on Lock Screen
Hi Forums,
Hope you’re all well. Can anyone help/point me in the right direction with this one please.
I’m trying to get my 2nd monitor to be disabled on the lock screen. I’ve managed to disable it for boot as well as disable it for the initial logon screen but I’d also like it off for when the screen is locked.
Any thoughts appreciated, here’s the inxi
╰─λ garuda-inxi
Kernel: 6.5.9-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=91f97d0a-076d-4d95-a0fb-2ea703fedc17 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.E0
date: 07/04/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3691 high: 3700 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700
12: 3700 13: 3700 14: 3700 15: 3700 16: 3700 17: 3700 18: 3700 19: 3599
20: 3700 21: 3700 22: 3700 23: 3599 24: 3700 bogomips: 177648
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Micro-Star MSI
driver: nvidia v: 535.113.01 alternate: nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 2d:00.0 chip-ID: 10de:2206 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:2
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 4920x2160 s-dpi: 140 s-size: 892x392mm (35.12x15.43")
s-diag: 974mm (38.36")
Monitor-1: DP-0 pos: primary,top-right res: 3840x2160 dpi: 139
size: 700x390mm (27.56x15.35") diag: 801mm (31.55") modes: N/A
Monitor-2: HDMI-0 pos: bottom-l res: 1080x1920 dpi: 93
size: 296x527mm (11.65x20.75") diag: 604mm (23.8") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 535.113.01
device-ID: 10de:2206 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 2d:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
Device-4: XMOS [] driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4:3 chip-ID: 20b1:3008
API: ALSA v: k6.5.9-AMD-znver3 status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 3.64 TiB used: 833.99 GiB (22.4%)
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 613200WD temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 42.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 871.43 GiB size: 871.43 GiB (100.00%)
used: 22.09 GiB (2.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 487 MiB size: 486 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 483.86 GiB (26.0%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:5
ID-4: /var/log raw-size: 871.43 GiB size: 871.43 GiB (100.00%)
ID-5: /var/tmp raw-size: 871.43 GiB size: 871.43 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 1.81 GiB (5.8%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
ID-2: swap-2 type: partition size: 59.6 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 49.1 C mobo: N/A gpu: nvidia temp: 57 C
Processes: 465 Uptime: 16h 51m wakeups: 0 Memory: total: 32 GiB
available: 31.28 GiB used: 5.36 GiB (17.1%) Init: systemd v: 254
pm: pacman pkgs: 1979 libs: 569 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-21
Last full system update: 2023-10-30
I don’t think there’s a ready/baked-in way to do that.
However…
When there screen is locked or unlocked, a notification event is triggered.
Notifications → Application Specific settings [configure] → Screen Saver → [Configure Events]
There it will let you start a script. You could use xrandr to turn off/on the monitor.
Examples:
#!/bin/bash
xrandr --output HDMI-A-0 --off
#!/bin/bash
xrandr --output HDMI-A-1 --mode 1920x1080 --right-of HDMI-A-0
You’ll have to find out what your monitor output names are ‘n’ stuff. xrandr will help with that, too.
HTH :slightly_smiling_face:
Thanks for the tip.
Going to need to play, running xrandr --output HDMI-0 --off does indeed switch the monitor off however trying to get it to come back on with xrandr --output HDMI-0 --mode 1920x1080 --rate 74.97 --rotation left --auto isn’t playing ball.
Experimenting…
