Different dotnet-runtime required for pinta
Hi everyone!
When I try to update my system, it always gives me the following error and cancels the process:
:: installing dotnet-runtime (8.0.0.sdk100-2) breaks dependency 'dotnet-runtime-7.0' required by pinta
I guess I could solve the problem by uninstalling pinta, but is there an easy fix to this, so I could keep pinta, or should I switch the program?
Also, is it still required to provide the garuda-inxi even in cases like these, where is probably isn’t needed? ^^’
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=190e7cc2-4318-4f40-8d3a-f5f4b453777f rw rootflags=subvol=@
resume=UUID=7c8380c2-84ce-492e-b61f-aa22976a6b16 loglevel=3 ibt=off
Type: Desktop Mobo: Gigabyte model: B650 AORUS ELITE AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F4
date: 03/22/2023
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1381 high: 3767 min/max: 400/5573 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 3767 3: 400
4: 3599 5: 400 6: 3505 7: 400 8: 400 9: 3234 10: 400 11: 400 12: 400
13: 400 14: 400 15: 3592 16: 400 bogomips: 143728
Device-1: NVIDIA GA102 [GeForce RTX 3090] driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-2 empty: DP-4,DP-5,DP-6 bus-ID: 01:00.0 chip-ID: 10de:2204
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1, DP-2,
DP-3, HDMI-A-1 bus-ID: 11:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 32.0 C
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
s-diag: 610mm (24")
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled model: Asus VG248
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
max: 1920x1080 min: 640x480
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
memory: 23.44 GiB
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3090 driver: nvidia v: 545.29.06
device-ID: 10de:2204 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aef
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Yamaha AG06/AG03 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.2.1:4 chip-ID: 0499:170d
class-ID: 0103
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp13s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 0e8d:0616
Local Storage: total: 3.64 TiB used: 374.63 GiB (10.1%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 31.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 35.9 C
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 208.61 GiB (11.4%)
used: 208.61 GiB (11.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 33.55 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 30.5 GiB used: 78.8 MiB (0.3%) priority: 100
System Temperatures: cpu: 36.6 C mobo: 30.0 C
GPU: device: nvidia screen: :0.0 temp: 41 C fan: 0% device: amdgpu
temp: 32.0 C
Processes: 494 Uptime: 1h 52m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.5 GiB used: 9.6 GiB (31.5%) Init: systemd v: 254
pm: pacman pkgs: 1458 libs: 419 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-09-25
Last full system update: 2023-11-30
Yes.
Not everyone can judge whether it makes sense in their case or not.
Discussions about this can be avoided if everyone adheres to the guidelines and makes the work of the forum helpers much easier.
I have deleted pinta, if the developer has updated his app, you can install it again. A note or MR on GitHub or GitLab could also help.
dotnet-runtime-7.0 has been updated 40 minutes ago.
Maybe this was fixed.
Try again in a few minutes.
Oh… That is very new. Should’ve looked that up.^^’
I was just about to uninstall the program and reply to SGS when I saw your comment, I guess I’ll wait a bit to see if the app gets updated in that case. I guess the topic can be closed in that case.
Thank you both for your very fast answers and keeping such a nice distro up and running! :slight_smile:
