Hello everyone, i have a weird issue, for some reason i get consistently faster internet speeds between bootable usb and fully installed system
Fully installed Garuda, updated as of today. (obv. nothing was in the background while running speedtest, no torrents, nothing as far as i know)
System from Live-usb garuda-dr460nized-linux-zen-220909.iso using browser that was shipped with Live-USB aka FireDragon.
So what i've tried:
• latest FireDragon, Firefox, Google chrome and Brave, all of them gave same speeds within margin of error.
• diffent kernels - Latest Arch, Xanmod-tt 5.15
• Mitigations on/off
• tried on/off Power saving options
• tried on/off Performance options
• tried forcing 1gbit speed in the internet settings --> link negotiation
inxi -Faz from Installed system:
â•─aqua@aqua in ~
╰─λ inxi -Faz
root=UUID=723b7c64-c203-418d-b27c-4d67f33d0e69 rw rootflags=subvol=@
loglevel=3 mitigations=off
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: X79-UP4 v: x.x serial: <superuser required>
UEFI: American Megatrends v: F6a date: 12/18/2013
Info: model: Intel Core i7-3930K bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 3 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2D (45) stepping: 7 microcode: 0x71A
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 5695 high: 5900 min/max: 1200/5900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 5900 2: 5900 3: 5900
4: 5900 5: 5900 6: 3442 7: 5900 8: 5900 9: 5900 10: 5900 11: 5900
12: 5900 bogomips: 76803
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M] vendor: Tul
/ PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:73df class-ID: 0300
s-diag: 1052mm (41.43")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Samsung
built: 2010 res: 1920x1080 hz: 60 dpi: 55 gamma: 1.2
size: 886x498mm (34.88x19.61") diag: 551mm (21.7") ratio: 16:9 modes:
Monitor-2: DP-3 mapped: DisplayPort-2 pos: primary,right model: LG
(GoldStar) FULL HD serial: <filter> built: 2020 res: 1920x1080 hz: 60
dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7")
OpenGL: renderer: AMD Radeon RX 6700 XT (navi22 LLVM 14.0.6 DRM 3.48
6.0.2-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:ab28
Device-1: Intel 82579LM Gigabit Network vendor: Gigabyte driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Local Storage: total: 592.05 GiB used: 23.46 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Gigabyte model: GP-GSTFS31120GNTD
type: SSD serial: <filter> rev: 11.3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HM250HI
size: 232.88 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 01C4 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra Fit
size: 14.48 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 16.12 GiB
(14.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
(0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 16.12
GiB (14.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 16.12
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 16.12
ID-1: swap-1 type: zram size: 31.27 GiB used: 1.5 MiB (0.0%)
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 30.0 C
Processes: 305 Uptime: 43m wakeups: 0 Memory: 31.27 GiB used: 3.19 GiB
(10.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1482
libs: 478 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
inxi -Faz from Live-USB:
â•─garuda@garuda in ~ as đź§™
╰─λ inxi -Faz
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON quiet
systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
gen: core 3 built: 2010-12 process: Intel 32nm family: 6
Speed (MHz): avg: 2125 high: 5900 min/max: 1200/5900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1200 3: 1200
4: 3800 5: 1200 6: 5000 7: 5900 8: 1200 9: 1200 10: 1200 11: 1200
12: 1200 bogomips: 76802
vulnerable
Monitor-2: DP-3 mapped: DisplayPort-2 pos: right model: LG (GoldStar)
FULL HD serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 14.0.6 DRM
3.47 5.19.7-zen2-1-zen) v: 4.6 Mesa 22.1.7 direct render: Yes
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
Local Storage: total: 592.05 GiB used: 102.16 GiB (17.3%)
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 30.0 C
Processes: 306 Uptime: 12m wakeups: 0 Memory: 31.27 GiB used: 3.31 GiB
(10.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1181 lib: 303 Shell: fish v: 3.5.1
