I’ve noticed on more than one OS including Garuda that after a period of time dialog boxes do not popup where they should and are much larger than they should be. For example when I connect my phone and the devices one opens it’s in the center of the screen instead of the upper right corner and much larger than it should be. I click on shutdown Or Switch and it’s dialog box opens in the right spot on the screen but much larger than it should be. Same with clicking the Application Launcher as the devices dialog. When I’m copying or movie files / folders the indicator only show on the main virtual desktop instead of all of them like it should.
╭─cccp@CCCP in ~
╰─λ garuda-inxi
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=85940f0b-f078-457f-89a1-1f9d08a9eeb7 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
UEFI: American Megatrends v: 3607 date: 03/22/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3483 high: 3593 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3593
3: 3400 4: 3592 5: 3400 6: 3400 7: 3400 8: 3591 9: 3593 10: 3400 11: 3400
12: 3593 13: 3400 14: 3587 15: 3592 16: 3400 bogomips: 108599
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-1 empty: DP-2,DP-3,HDMI-A-1
bus-ID: 0a:00.0 chip-ID: 10de:2504 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-1 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
API: Vulkan v: 1.3.295 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 560.35.03
device-ID: 10de:2504 surfaces: xcb,xlib,wayland
bus-ID: 0a:00.1 chip-ID: 10de:228e class-ID: 0403
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 13d3:3563
Device-2: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.4:12 chip-ID: 8087:0029
Report: ID: hci1 rfk-id: 2 state: up address: <filter> bt-v: 5.2 lmp-v: 11
status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 34.11 TiB used: 18.9 TiB (55.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR002 temp: 32.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 30.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
size: 14.55 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 1801 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: Expansion HDD
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0003 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: Expansion HDD
ID-1: / raw-size: 698.41 GiB size: 698.41 GiB (100.00%)
used: 20.4 GiB (2.9%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
used: 182.4 MiB (60.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 698.41 GiB size: 698.41 GiB (100.00%)
ID-4: /var/log raw-size: 698.41 GiB size: 698.41 GiB (100.00%)
ID-5: /var/tmp raw-size: 698.41 GiB size: 698.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.96 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.1 C mobo: N/A
Memory: total: 48 GiB available: 46.96 GiB used: 7.58 GiB (16.1%)
Processes: 442 Power: uptime: 2h 46m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.73 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1911 libs: 542
tools: octopi,pacseek,paru,pikaur,yay Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-09-19
Last full system update: 2024-09-20
