Trying to get a hand on linux file system here. I have nvme0n1 which is my primary drive holding ‘boot’, ‘swap’ and ‘/’, I also got nvme1n1 which I have mounted to ‘home/idun9/data’ which will act more of a permanent drive for moving a bit more around but will be my main source of allways keep data. Somewhat similar to D:\ drive in windows.
As for devices view in Dolphin, when i enter nvme1n1 there is a lost & found folder, this is used to recover files that are not linked to any place and should be kept there for safe keeping. Is there some way to hide it as it’s not really needed for me, then I can bring it backup? And how can i create new folders inside nvme1n1, from device or from ‘home/idun9/data’ im not able to create subfolders, the option is blocked. Checking the permission vs nvme0n1 they seem correct.
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7f46e19d-2a13-4dff-b8de-ea5c58cb4ff6 rw rootflags=subvol=@
quiet resume=UUID=f95e715b-109c-46fb-94d9-803bcd80b3b4 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: Micro-Star model: B650 GAMING PLUS WIFI (MS-7E26) v: 1.0
serial: <filter> uuid: c79c34b3-2846-a518-a5c9-d843ae4c48ac UEFI: American
Megatrends LLC. v: 1.A0 date: 03/27/2024
Info: model: AMD Ryzen 7 7800X3D socket: AM5 bits: 64 type: MT MCP
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2892 high: 4402 min/max: 400/5050 base/boost: 4200/5050
scaling: driver: amd-pstate-epp governor: powersave volts: 1.3 V
ext-clock: 100 MHz cores: 1: 4377 2: 4385 3: 4398 4: 400 5: 4400 6: 4380
7: 400 8: 400 9: 400 10: 4394 11: 4361 12: 400 13: 4396 14: 400 15: 4390
16: 4402 bogomips: 134402
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Gigabyte driver: nvidia
v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
off: DP-3,HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2206 class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-3, Writeback-1 bus-ID: 14:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 33.0 C
Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-5.2:6
chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
Display: server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1054x342mm (41.50x13.46")
s-diag: 1108mm (43.63")
Monitor-1: DP-3 mapped: DP-4 note: disabled pos: primary,left
model: Asus ROG PG278Q serial: <filter> built: 2015 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
ratio: 16:9 modes: 2560x1440
Monitor-2: HDMI-A-2 mapped: HDMI-1 note: disabled pos: right
model: BenQ GL2450H serial: <filter> built: 2012 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 550.76 device-ID: 10de:2206
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:164e surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
Device-2: AMD Rembrandt Radeon High Definition Audio
speed: 16 GT/s lanes: 16 bus-ID: 14:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 14:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
Device-5: Astro Gaming A50 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2:2
chip-ID: 9886:002c class-ID: 0300
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0f:00.0
IF: enp15s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 10:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp16s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-7:5 chip-ID: 0e8d:0616
Local Storage: total: 5.46 TiB used: 295.82 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 31 hrs cycles: 17
read-units: 495,797 [253 GB] written-units: 999,744 [511 GB]
model: WD Green SN350 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 33006000 temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 5d 20h cycles: 28 read-units: 968 [495 MB]
written-units: 122 [62.4 MB]
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 15d 18h cycles: 271
written: 1.89 TiB
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000524AS
family: Barracuda 7200.12 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: JC4B temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 241d 21h cycles: 2500
read: 526.98 GiB written: 366.31 GiB Pre-Fail: attribute: Spin_Retry_Count
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 295.81 GiB (16.5%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:4
used: 620 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:3
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 295.81 GiB (16.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:4
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
maj-min: 259:4
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
maj-min: 259:4
ID-1: swap-1 type: zram size: 61.98 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 68.18 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 36.8 C mobo: 32.0 C
GPU: device: nvidia screen: :0.0 temp: 44 C fan: 0% device: amdgpu
temp: 33.0 C
Memory: total: 64 GiB note: est. available: 61.98 GiB used: 3.3 GiB (5.3%)
Processes: 370 Power: uptime: 33m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.75 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1588 libs: 483 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date: 2024-04-21
Last full system update: 2024-04-21
Windows dual boot: Yes
