Desktoptheme ändern?
root=UUID=1806c6c9-691b-48f3-8e16-b5618d02dfaa rw [email protected]
loglevel=3 ibt=off
Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37 wm: muffin vt: 8 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Virtualbox System: innotek GmbH product: VirtualBox v: 1.2
serial: Chassis: Oracle Corporation type: 1
serial:
Mobo: Oracle model: VirtualBox v: 1.2 serial:
BIOS: innotek GmbH v: VirtualBox date: 12/01/2006
Info: model: AMD A6-6420K APU with Radeon HD Graphics bits: 64 type: MCP
arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 0x13 (19) stepping: 1 microcode: N/A
Topology: cpus: 1x cores: 2 smt: cache: L1: 160 KiB
desc: d-2x16 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 3993 min/max: N/A cores: 1: 3993 2: 3993 bogomips: 15970
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.20.0.0 ports:
active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
Virtual-6, Virtual-7, Virtual-8 bus-ID: 00:02.0 chip-ID: 15ad:0405
Display: x11 server: [X.Org](http://X.Org) v: 21.1.8 driver: X: loaded: vmware
unloaded: modesetting alternate: fbdev,vesa gpu: vmwgfx display-ID: :1
Screen-1: 0 s-res: 1920x937 s-dpi: 96 s-size: 508x247mm (20.00x9.72")
s-diag: 565mm (22.24")
Monitor-1: Virtual-1 mapped: Virtual1 res: 1920x937 hz: 60 size: N/A
modes: max: 1920x937 min: 640x480
missing.
Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0
v: kernel bus-ID: 00:05.0 chip-ID: 8086:2415 class-ID: 0401
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: d020
bus-ID: 00:03.0 chip-ID: 8086:100e class-ID: 0200
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
driver: piix4_smbus v: N/A modules: i2c_piix4 port: N/A bus-ID: 00:07.0
chip-ID: 8086:7113 class-ID: 0680
Local Storage: total: 46.41 GiB used: 3.54 GiB (7.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: VirtualBox model: VBOX HARDDISK
size: 46.41 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: rev: 1.0 scheme: MBR
ID-1: / raw-size: 46.41 GiB size: 46.41 GiB (100.00%) used: 3.54 GiB (7.6%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 46.41 GiB size: 46.41 GiB (100.00%)
used: 3.54 GiB (7.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 46.41 GiB size: 46.41 GiB (100.00%)
ID-4: /var/tmp raw-size: 46.41 GiB size: 46.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 4.06 GiB used: 0 KiB (0.0%) priority: 100
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Processes: 248 Uptime: 1h 15m wakeups: 3349 Memory: 4.06 GiB
used: 1.87 GiB (46.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1159
libs: 325 tools: paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.26
System install date: 2023-05-22
Last full system update: 2023-05-22
Is partially upgraded: Yes
Windows dual boot:
Wie kann ich wenn ich garuda-Live also von USB-Stick gestartet habe, das Desktoptheme ändern?
Du kannst auch von der live ISO garuda-inxi posten.
Damit wir nicht fragen müssen, welches DE du benutzt.
Du warst nach meinem Posting im Forum ohne zu Antworten.
Bitte ändere deinen OP mit der Ausgabe von garuda-inxi als Text und der Topic wird wieder geöffnet.
Nebenbei ist das jetzt das 7. Thema, wo du nicht dem Template folgst.
Edit:
Das ist keine live ISO.
