Desktop keeps freezing even after fresh installation
Kernel: 6.12.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=87ddf318-ee41-4913-894a-f50ea42a706e rw rootflags=subvol=@
quiet resume=UUID=d28e20c4-f064-4e5d-91a4-fa93570fa1b2 loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF
Megatrends LLC. v: F65d date: 09/02/2024
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1281 min/max: 1400/3600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1281 2: 1281 3: 1281
4: 1281 bogomips: 28798
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Gigabyte driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: none
bus-ID: 0a:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 33.0 C
Monitor-1: HDMI-A-1 res: 1366x768 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 18.1.8 DRM 3.59 6.12.6-zen1-1-zen)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15d8
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.1 chip-ID: 1002:15de class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.6-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
chip-ID: 10ec:8179 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
Local Storage: total: 238.47 GiB used: 15.86 GiB (6.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-GSM2NE3256GNTD size: 238.47 GiB block-size: physical: 512 B
fw-rev: EDFM00.7 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 15.86 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.7 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
System Temperatures: cpu: 32.8 C mobo: N/A gpu: amdgpu temp: 32.0 C
Memory: total: 6 GiB available: 5.7 GiB used: 2.15 GiB (37.7%)
Processes: 271 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.27 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1383 libs: 407 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-12-27
Last full system update: 2024-12-27
I am daily driving garuda for quite a while now and everything was working ok up until two days ago where my pc started freezing up. Most often it would freeze up when i would be browsing , so i thought to start fresh and reinstall the system, but even after the fresh installation the problem keeps occurring usually when i am browsing (it happend on firedragon as well as brave). If a video was playing or i was listening to music it would be stack on the audio of the last 2 or 3 seconds and it would keep on playing on a loop those last seconds, when this happens i either click the restart button or i would press the power off button until it was shutdown any commands throw the keyboard or moving the mouse want do a thing. After the fresh install I also tried to change kernels i used the lts one but i still faced the same problem. Lastly something i found out after the installation of the system when i went to garuda assistance > other diagnostics and i would click on journal errors this is what i get
Dec 27 23:12:05 black systemd-modules-load[157]: Failed to find module 'v4l2loopback-dc'
Dec 27 23:12:07 black systemd-modules-load[401]: Failed to find module 'v4l2loopback-dc'
Dec 27 23:12:10 black kernel: amdgpu 0000:0a:00.0: amdgpu: Secure display: Generic Failure.
Dec 27 23:12:10 black kernel: amdgpu 0000:0a:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Dec 27 23:12:21 black 30-systemd-environment-d-generator[1252]: /home/sirius/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignoring.
Dec 27 23:12:21 black 30-systemd-environment-d-generator[1501]: /home/sirius/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignoring.
Dec 27 23:12:23 black org_kde_powerdevil[1892]: busno=0, sleep-multiplier =  1.30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
Dec 27 23:12:24 black plasmashell[1828]: aurorae: Couldn't find QML Decoration  ""
Dec 27 23:15:11 black sudo[3343]:   sirius : a password is required ; TTY=pts/0 ; PWD=/home/sirius ; USER=root ; COMMAND=/usr/bin/true
Dec 27 23:15:21 black sudo[3652]:   sirius : a password is required ; TTY=pts/0 ; PWD=/home/sirius ; USER=root ; COMMAND=/usr/bin/true
and after a bit of search I am not sure if any of the above errors might be the reason for the problem i still face. Any suggestions are welcomed , thanks in advance !
Browsers consume a lot of storage space. Have you tried X11 on the login screen? Is the cooling working? Watch temperature and memory load with htop. Also look at the journal jctl in the terminal. For Resources hungry DE like KDE seems your CPU and RAM are too weak :man_shrugging: . Just my opinion…
is for smoother/better scrolling (2 finger) with a touchpad. This option is now also default for firefox.
If you don´t use a touchpad comment it out or ignore this message.
https://bbs.archlinux.org/viewtopic.php?id=265153
your third issue is
missing firmware file/s or “bad” bios (not shure)
try reinstall firmware or
install firmware gid (perhaps there are the missing files)
take a look in your bios also
Initial Display Output -->IGD Video
Sets the onboard graphics as the first display
( that´s not the problem only a faster boot time)
and if possible spend money for ram/cpu or install another DE with less on resources example xfce …also just my opinion…
Similar issue to yours , try the linux or linux-lts kernel.
Install with:
sudo pacman -S linux linux-headers
And reboot and see for changes.
Else,
And reboot.
Idk but once I manually did btrfs-scrub and stuff with the btrfs maintenance or assist tool, and it wrecked havoc on my install HDD. (on a different Arch based distro).
Perhaps Garuda’s automatic maintenance for btrfs is causing these freezes, idk if it is recommended to mess with these options but you should be able to disable btrfs maintenance from Garuda assistant, Btrfs assistant/maintenance or something as a last resort.
