"Desktop Effects were restarted due to a graphics reset"
Kernel: 6.17.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=4ea673d3-c485-4120-97a1-b138e410ea3e rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING WIFI II v: Rev X.0x
UEFI: American Megatrends v: 3631 date: 08/08/2025
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201213
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1750 min/max: 565/4687 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1750 2: 1750 3: 1750
4: 1750 5: 1750 6: 1750 7: 1750 8: 1750 9: 1750 10: 1750 11: 1750 12: 1750
bogomips: 83848
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
XT/6600M] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
Writeback-1 bus-ID: 09:00.0 chip-ID: 1002:73ff class-ID: 0300
Monitor-1: HDMI-A-1 model: Acer P235H serial: <filter> built: 2009 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 21.1.5 DRM 3.64 6.17.8-zen1-1-zen) device-ID: 1002:73ff
API: Vulkan v: 1.4.328 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.2.7-arch1.1
device-ID: 1002:73ff surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.5 256 bits) driver: mesa llvmpipe v: 25.2.7-arch1.1 (LLVM
21.1.5) device-ID: 10005:0000 surfaces: N/A
bus-ID: 09:00.1 chip-ID: 1002:ab28 class-ID: 0403
lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.17.8-zen1-1-zen status: kernel-api with: aoss
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
chip-ID: 8086:125c class-ID: 0200
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0489:e0e2
Local Storage: total: 4.55 TiB used: 31.27 GiB (0.7%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 25.9 C scheme: GPT
model: WD40EZRX-00SPEB0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
used: 31.27 GiB (3.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 31.8 C mobo: 26.0 C gpu: amdgpu temp: 24.0 C
mem: 16.0 C
Memory: total: 16 GiB available: 15.52 GiB used: 2.79 GiB (18.0%)
Processes: 412 Power: uptime: 3h 48m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1785 libs: 473 tools: octopi,paru,yay
Compilers: clang: 21.1.5 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish
v: 4.2.1 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date:     2025-11-17
Last full system update: 2025-11-18
Recently shifted from windows to linux, started out with this distribution, but recently Ive been having graphics issues. Up until recently, my screen would freeze, and after about half a minute, whole screen would go black, all apps but Firedragon would close, and i would get a notification saying that “Desktop effects were restarted due to a graphics reset” from KWin Window Manager. However, today, it would reset whenever i opened a new application. I wasn’t able to find much only, the only concrete thing that most sources were able to provide was to disable complications, but when i tried to follow the steps given to do that, i couldn’t find the setting needed. It appears to me at least that both my gpu and drivers are compatible, and the only other reason i can think of for why this would be happening as a highly inexperienced user of linux would be low ram, but i have 16GB installed, and windows is supposed to be more resource hungry than most linux distros, from what i have learned.
For context, This issue started happening about 2-3 hours of game play in a minecraft modpack I’ve been playing for about a week at this point, but i only have 8GB allocated to it, and it hasn’t given me a low ram space warning yet. Fro what i know of, I haven’t installed additional desktop effect plugins, just added or removed a few of the ones already available at install. The only other post on here with the same issue didn’t get any response or solutions, so idk how that user fixed it, if at all. Is there anything else i could try or need to look at to get this issue solved?
Remove that, modpacks/shaders are often the cause of issues with graphics drivers.
If you haven’t already done so, please bring your system up to date and then check if the issue still occurs.
Sounds like an issue with the graphics driver, which is probably causing kwin/plasmashell/compositor to crash and restart. Does this only happen with certain applications or with all of them? Are you using a custom theme and/or have you installed user-created widgets (plasmoids)?
As soon as it happens again, use
garuda-diag
in the terminal and post the generated link here.
ill try disabling the shaders, see if that helps, and my system is completely up to date, although curseforge seems unable to update, for whatever reason.
Unsure I dont think im using a custom theme, using one of the ones that came preinstalled, but i did install a plugin for my background, but its just an image.
Don’t just disable it, remove it. The point is to rule it out as a possible cause.
Which plugin exactly?
You are using curseforge from the AUR – to update AUR packages during a system update, use:
garuda-update -a
Gently-Nebula-Noir Wallpapers by l4k1 under the Get New Images in the Wallpaper settings.
I thought that disabling wouldve done the same, but i will completely remove them now.
Havent had a reset in a bit now, so will post the link in the next comment if it happens by then.
Welp, spoke too soon Here’s the link @nepti :
Since when exactly have you had this issue, from the beginning?
The installation is quite new. Did you have this issue after the installation and after the first system update, or only after you installed other packages, such as curseforge, reshade-shaders-git, etc.?
Nov 22 01:29:42 wabbitseason firedragon[23888]: Crash Annotation GraphicsCriticalError: |[0][GFX1-]: Detect DeviceReset DeviceResetReason::DRIVER_ERROR DeviceResetDetectPlace::WR_POST_UPDATE in Parent process (t=28866.6) |[166][GFX1-]: Failed to compile vertex shader: brush_image_ALPHA_PASS_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[167][GFX1-]: Failed to compile vertex shader: ps_text_run_ALPHA_PASS_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[168][GFX1-]: Failed to compile vertex shader: brush_image_ALPHA_PASS_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[169][GFX1-]: Failed to compile vertex shader: brush_opacity_ALPHA_PASS
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[170][GFX1-]: Failed to compile vertex shader: ps_quad_textured
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[156][GFX1-]: Failed to compile vertex shader: brush_image_ALPHA_PASS_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[157][GFX1-]: Failed to compile vertex shader: brush_image_ALPHA_PASS_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[158][GFX1-]: Failed to compile vertex shader: brush_image_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[159][GFX1-]: Failed to compile vertex shader: ps_quad_textured
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[160][GFX1-]: Failed to compile vertex shader: brush_image_ALPHA_PASS_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[161][GFX1-]: Failed to compile vertex shader: brush_image_ALPHA_PASS_ANTIALIASING_REPETITION_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[162][GFX1-]: Failed to compile vertex shader: brush_solid_ALPHA_PASS
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[163][GFX1-]: Failed to compile vertex shader: brush_image_ALPHA_PASS_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[164][GFX1-]: Failed to compile vertex shader: ps_text_run_ALPHA_PASS_TEXTURE_2D
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) |[165][GFX1-]: Failed to compile vertex shader: ps_quad_textured
Nov 22 01:29:42 wabbitseason firedragon[23888]:  (t=28916.9) [GFX1-]: Failed to compile vertex shader: ps_quad_textured
Nov 22 01:29:42 wabbitseason firedragon[23888]: [ERROR webrender::device::gl] Failed to compile vertex shader: ps_quad_textured
firedragon throws several shader errors (OpenGL) in one second (driver error).
Nov 22 01:29:54 wabbitseason kwin_wayland[6345]: 0x3: GL_CONTEXT_LOST in context lost
kwin_wayland throws OpenGL errors (probably driver error).
Nov 22 01:30:01 wabbitseason systemd-coredump[59268]: Process 24490 (java) of user 1000 dumped core.
                                                      Module /run/media/valor/c3456484-b8dc-4018-a18a-1296ac18f717/CurseForge Modpacks/Install/java/java-runtime-delta/bin/java without build-id.
                                                      Module /tmp/libtmp2654890575835125541libjunixsocket-native-2.6.2.so (deleted) without build-id.
                                                      Module libsyslookup.so without build-id.
                                                      Module libawt_headless.so without build-id.
                                                      Module libawt.so without build-id.
                                                      Module libextnet.so without build-id.
                                                      Module libprefs.so without build-id.
                                                      Module libmanagement_ext.so without build-id.
                                                      Module libmanagement.so without build-id.
                                                      Module libverify.so without build-id.
                                                      Module libzip.so without build-id.
                                                      Module libnet.so without build-id.
                                                      Module libnio.so without build-id.
                                                      Module libjsvml.so without build-id.
                                                      Module libjava.so without build-id.
                                                      Module libjimage.so without build-id.
                                                      Module libjvm.so without build-id.
                                                      Module libjli.so without build-id.
                                                      Stack trace of thread 24589:
                                                      #0  0x00007fa486c255df abort (libc.so.6 + 0x255df)
                                                      #1  0x00007fa37dc6d1e3 n/a (libgallium-25.2.7-arch1.1.so + 0xa6d1e3)
                                                      #2  0x00007fa37dc714d4 n/a (libgallium-25.2.7-arch1.1.so + 0xa714d4)
                                                      #3  0x00007fa37d720955 n/a (libgallium-25.2.7-arch1.1.so + 0x520955)
                                                      #4  0x00007fa37d76784d n/a (libgallium-25.2.7-arch1.1.so + 0x56784d)
                                                      #5  0x00007fa486c9698b n/a (libc.so.6 + 0x9698b)
                                                      #6  0x00007fa486d1a9cc n/a (libc.so.6 + 0x11a9cc)
java (from a modpack :roll_eyes: ) crashes (driver error).
Nov 22 01:30:02 wabbitseason kernel: amdgpu 0000:09:00.0: amdgpu: VM memory stats for proc java(24589) task java:cs0(24490) is non-zero when fini
Looks like a memory leak or resource issue in the driver.
Nov 22 01:30:10 wabbitseason systemd-coredump[59369]: Process 37234 (Discord) of user 1000 dumped core.
                                                      Stack trace of thread 37280:
                                                      #0  0x00007fb1cf09890c n/a (n/a + 0x0)
                                                      ELF object binary architecture: AMD x86-64
discord crashes.
Nov 22 01:30:10 wabbitseason systemd-coredump[59369]: Removed old coredump core.Discord.1000.6731834ab00b4d09848f9944431d144d.6278.1763543337000000.zst.
Nov 22 01:30:10 wabbitseason systemd-coredump[59369]: Removed old coredump core.Discord.1000.6731834ab00b4d09848f9944431d144d.7067.1763543330000000.zst.
Nov 22 01:30:10 wabbitseason systemd-coredump[59369]: Removed old coredump core.curseforge.1000.6731834ab00b4d09848f9944431d144d.27110.1763543336000000.zst.
Nov 22 01:30:10 wabbitseason systemd-coredump[59369]: Removed old coredump core.Xwayland.1000.6731834ab00b4d09848f9944431d144d.53055.1763589207000000.zst.
Nov 22 01:30:10 wabbitseason systemd-coredump[59369]: Removed old coredump core.plasmashell.1000.6731834ab00b4d09848f9944431d144d.53010.1763589208000000.zst.
Nov 22 01:30:10 wabbitseason systemd-coredump[59369]: Removed old coredump core.java.1000.6731834ab00b4d09848f9944431d144d.86788.1763589207000000.zst.
The dumps show what else crashed. The whole thing smells strongly of driver issues.
Please try the linux-znver3 kernel:
sudo pacman -S linux-znver3 linux-znver3-headers
Then reboot and select this kernel in the grub menu and test whether the issues still occur.
If no issues occur with this kernel, set it as the default kernel via “Garuda Boot Options”.
And remove all that shader/modpack stuff.
The first time this had happened was after i had installed all of my apps, a few hours into playing the modpack.
Shaders have been deleted, but unsure what you mean by deleteing the modpack, but since thats where the issues have been occuring, i wouldnt remove them just yet.
Installed and booted with, only had installed the base drivers that the system auto installed.
I have run into the same situation yesterday. I have also a year ago switch from windows to Garuda linux and run with the same desktop environment and zen core. I was playing ark survival ascended on steam that I have been playing time as I have installed Linux and never had such an issue that now occurred that the game crashes as soon as I access my inventory in game and discord shuts down and desktop environment restarted and sometimes after crash desktop doesn’t restart that forces me to force restart my pc.
Please, open a new help request under Games > Games On Steam and follow the template.
