In plasma 6 wayland (nvidia), desktop cube effect’s skybox background is not working, tried all extensions .hdr .exr .jpeg .png but none worked
Am talking about :
Desktop Effects > Cube > Skybox local path
Please help
garuda-inxi : (partially updated - yes but due to installing one software only, no issues of upgrading, system updated recently)
Kernel: 6.10.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=994440bb-4224-4ac7-bc5d-6f26fb2e7d1c rw rootflags=subvol=@
quiet loglevel=3 nvidia_drm.modeset=1 nvidia_drm.fbdev=1 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
wm: kwin_wayland with: Docker,krunner tools: avail: xautolock vt: 1 dm:
1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: ASUSTeK product: G751JL v: 1.0
Mobo: ASUSTeK model: G751JL v: 1.0 serial: <superuser required>
part-nu: ASUS-NotebookSKU uuid: <superuser required>
UEFI: American Megatrends v: G751JL.205 date: 11/02/2015
ID-1: BAT0 charge: 44.9 Wh (95.9%) condition: 46.8/66.0 Wh (70.9%)
volts: 15.0 min: 15.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
Info: model: Intel Core i7-4720HQ bits: 64 type: MT MCP arch: Haswell
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2443 high: 3539 min/max: 800/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 3410 3: 3510
4: 800 5: 3258 6: 3434 7: 800 8: 3539 bogomips: 41501
Device-1: NVIDIA GM204M [GeForce GTX 965M] vendor: ASUSTeK driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: eDP-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 01:00.0
chip-ID: 10de:13d9 class-ID: 0300
Device-2: Chicony USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:5 chip-ID: 04f2:b414
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 965M/PCIe/SSE2
memory: 1.95 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 965M driver: nvidia v: 555.58.02
device-ID: 10de:13d9 surfaces: xcb,xlib,wayland
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: NVIDIA GM204 High Definition Audio driver: snd_hda_intel
chip-ID: 10de:0fbb class-ID: 0403
API: ALSA v: k6.10.3-zen1-2-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wls1 state: down mac: <filter>
vendor: ASUSTeK driver: r8168 v: 8.053.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 3c:00.0 chip-ID: 10ec:8168
IF: enp60s0 state: down mac: <filter>
IF-ID-1: wlp0s20u4i2 state: up mac: <filter>
Device-1: Realtek 802.11ac NIC driver: btusb,rtw_8821cu type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:9 chip-ID: 0bda:c820
Report: btmgmt ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Device-2: Intel Bluetooth wireless interface driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:4
chip-ID: 8087:0a2a class-ID: e001
Report: ID: hci1 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.38 TiB used: 103.51 GiB (7.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU630 size: 447.13 GiB
block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s tech: SSD
serial: <filter> fw-rev: 4c21 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Generic model: STORAGE DEVICE
size: 29.83 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0819 scheme: MBR
ID-1: / raw-size: 97 GiB size: 97 GiB (100.00%) used: 29.87 GiB (30.8%)
fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-2: /boot/efi raw-size: 615.8 MiB size: 614.6 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/sdb7 maj-min: 8:23
ID-3: /home raw-size: 146.53 GiB size: 146.53 GiB (100.00%)
used: 73.64 GiB (50.3%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 97 GiB size: 97 GiB (100.00%)
used: 29.87 GiB (30.8%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-5: /var/tmp raw-size: 97 GiB size: 97 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.42 GiB used: 2.21 GiB (9.4%)
ID-2: swap-2 type: partition size: 8 GiB used: 2.2 MiB (0.0%) priority: -2
dev: /dev/sdb6 maj-min: 8:22
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2300
Memory: total: 24 GiB available: 23.42 GiB used: 7 GiB (29.9%)
Processes: 371 Power: uptime: 7h 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.31 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2065 libs: 467 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: yakuake inxi: 3.3.35
System install date: 2024-05-28
Last full system update: 2024-08-08
Is partially upgraded: Yes
Failed units: evdev-rce.service nvidia-powerd.service
