Kernel: 6.5.7-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=d629de94-f6be-4390-a8a9-f452f5e88d6e rw rootflags=subvol=@
Desktop: sway v: 1.8.1 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Laptop System: Micro-Star product: Bravo 15 B5ED v: REV:1.0
serial: Chassis: type: 10 serial:
Mobo: Micro-Star model: MS-158M v: REV:1.0 serial:
UEFI: American Megatrends LLC. v: E158MAMS.10A date: 07/06/2023
ID-1: BAT1 charge: 25.8 Wh (50.8%) condition: 50.8/52.0 Wh (97.7%)
volts: 11.6 min: 11.4 model: MSI Corp. MS-158M type: Li-ion serial: N/A
status: not charging
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/4463 scaling: driver: amd-pstate-epp
governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400
7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400
16: 400 bogomips: 102253
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 33.0 C
Display: wayland server: Xwayland v: 23.2.1 compositor: sway v: 1.8.1
driver: gpu: amdgpu display-ID: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 scale: 1.10000002384186
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.264 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1 type: cpu
speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Micro-Star MSI
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.5.7-AMD-znver3 status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac:
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:0608
IF: wlp5s0 state: up mac:
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0e8d:0608
class-ID: e001 serial:
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 8.09 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 tech: SSD serial: fw-rev: V3MA001 temp: 33.9 C
ID-1: / raw-size: 72.41 GiB size: 72.41 GiB (100.00%) used: 8.06 GiB (11.1%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 29.9 MiB (10.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 72.41 GiB size: 72.41 GiB (100.00%)
used: 8.06 GiB (11.1%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 72.41 GiB size: 72.41 GiB (100.00%)
ID-5: /var/tmp raw-size: 72.41 GiB size: 72.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.02 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
Processes: 344 Uptime: 35m wakeups: 377 Memory: total: 16 GiB note: est.
available: 15.02 GiB used: 3.32 GiB (22.1%) Init: systemd v: 254
pm: pacman pkgs: 1239 libs: 368 tools: octopi,pamac,paru,yay Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-20
Last full system update: 2023-10-21
During system upgrade pacman giving me dependency error . I have kwindowsystem5(5.110.0-1) installed on my system.
:: installing kwindowsystem5 (5.111.0-1) breaks dependency ‘kwindowsystem’ required by kvantum-git
