Dependency breaks, but file is not installed
  Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=7bbfb67a-37a6-4540-bbaf-fab8447d446c rw rootflags=subvol=@
  Desktop: MATE v: 1.26.1 info: mate-panel wm: marco v: 1.26.2 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Acer product: Nitro AN515-42 v: V1.13
  Mobo: RR model: Freed_RRS v: V1.13 serial: <superuser required>
    UEFI: Insyde v: 1.13 date: 02/11/2019
  ID-1: BAT1 charge: 36.6 Wh (100.0%) condition: 36.6/48.9 Wh (74.7%)
    volts: 16.2 min: 15.2 model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x4B
    type: Li-ion serial: <filter> status: not charging
  Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
    family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1768 high: 2387 min/max: 1600/2000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1527 2: 1600
    3: 1898 4: 1566 5: 1570 6: 1600 7: 2000 8: 2387 bogomips: 31941
  Device-1: AMD Baffin [Radeon RX 460/560D / Pro
    450/455/460/555/555X/560/560X] vendor: Acer Incorporated ALI driver: N/A
    alternate: amdgpu arch: GCN-4 code: Arctic Islands process: GF 14nm
    built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380
  Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
    lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0
    chip-ID: 1002:15dd class-ID: 0300 temp: 49.0 C
  Device-3: Quanta HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0408:a060
  Display: x11 server: X.Org v: 21.1.8 compositor: marco v: 1.26.2 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
  Monitor-1: eDP-1 mapped: eDP model: LG Display 0x05d8 built: 2018
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven
    LLVM 16.0.6 DRM 3.54 6.5.5-zen1-1-zen) device-ID: 1002:15dd
    memory: 1000 MiB unified: no
  API: Vulkan v: 1.3.264 layers: 7 device: 0 type: integrated-gpu name: AMD
    Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.1
    device-ID: 1002:15dd surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.1 (LLVM
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
  API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168
  IF: enp2s0f1 state: down mac: <filter>
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 42.0 C
  Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 04ca:3016 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 4 state: up address: <filter> bt-v: 4.2
  Local Storage: total: 1.02 TiB used: 752.2 GiB (72.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8120G
    tech: SSD serial: <filter> fw-rev: 61E1 scheme: MBR
  ID-1: / raw-size: 96 GiB size: 96 GiB (100.00%) used: 21.42 GiB (22.3%)
    fs: btrfs dev: /dev/sdb1 maj-min: 8:17
  ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
    used: 859 KiB (0.9%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
  ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 730.78 GiB (79.8%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  ID-4: /var/log raw-size: 96 GiB size: 96 GiB (100.00%)
    used: 21.42 GiB (22.3%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
  ID-5: /var/tmp raw-size: 96 GiB size: 96 GiB (100.00%)
  ID-1: swap-1 type: zram size: 30.26 GiB used: 2.05 GiB (6.8%)
  System Temperatures: cpu: 48.2 C mobo: N/A gpu: amdgpu temp: 48.0 C
  Processes: 343 Uptime: 1d 2h 39m wakeups: 9 Memory: total: 32 GiB note: est.
  available: 30.26 GiB used: 10.33 GiB (34.1%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1628
  pm: pacman pkgs: 1621 libs: 518 tools: gnome-software,octopi,pamac,paru,yay
  pm: flatpak pkgs: 7 Shell: Bash v: 5.1.16 running-in: mate-terminal
  inxi: 3.3.30
  System install date:     2023-08-28
  Last full system update: 2023-09-30
  Is partially upgraded:   Yes
  Failed units                        nmb.service
When I try to update, I get this:
garuda downloading...
 core downloading...
 extra downloading...
 multilib downloading...
 chaotic-aur downloading...
warning: vdhcoapp-git: local (2.0.0.r0.g6beaae1-1) is newer than chaotic-aur (1.6.3.r36.gedad10d-1)
resolving dependencies...
:: installing kvantum (1.0.10-2) breaks dependency 'kvantum-qt5' required by garuda-mate-settings
I tried
sudo pacman -R kvantum-qt5
error: target not found: kvantum-qt5
 -> exit status 1
What do I do? Using
yay -S kvantum-qt5
returns a file not found error.
How about
sudo pacman -Rdd garuda-mate-settings
then
garuda-update
since garuda-mate-settings is just a pkgbuild file used to create dependencies to bundle packages and make installing them easier you can forcefully remove it and still have all it’s installed “dependencies” available in your system and not be affected in anyway.
Or, you can wait it out until nico or whoever maintains this meta package updates its dependencies since kvantum-qt5 has been renamed in the repos so you won’t find it with that name anymore.
Thanks. That did it. I appreciate the rapid reply.
Be aware that as KDE transitions from Plasma 5 to Plasma 6, Arch Linux’ practice during such a major change is that package names may/will be incrementally change to denote their status in their appropriate repositories. Further, there will be a mix of the two, and applications, for at least a year following.
Plasma 4 to 5 was a mess. Plasma 3 to 4 was a mess…you get the picture. Smart :monkey: 's will be transitioning from KDE Plasma to GNOME Shell.
EDIT: I finally found the source and the correct nomenclature. The Arch Forums:
KDE is close to releasing new versions of their components based on QT 6 .
During the transition period from 5 to 6 (could be longer then a year) we’ll have a mix of 5 and 6 .
The convention on archlinux for such transitions is to give the ‘older’ version a suffix and let the version without a suffix become the latest version.
All kde 5 components in the repos are currently renamed to prepare for the transition . KDE is highly modular, so there could be dozens of components installed on your system. (mine had around 30 and that’s low for KDE)
Done! This will no longer occur with updated package databases.
