Hey,
How can i delete the monitor data.
Its because currently im using one monitor and if i connect the other monitor it goes to some saved settings, which is completly messed up. So how do i delete monitor data.
Thanks,
*Sorry if its confusing
Hey,
Thanks,
You mean the monitor settings, somewhere, stored depending on the DE.
The data you hide because you have not posted the required garuda-inxi.
You'll want to type in garuda-inxi
in your terminal, then edit your post and paste the output of that command onto your post.
Why are you repeating something the questioner has already deleted twice without addressing it?
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Im sorry,
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=2c3b8c16-aa70-4ea7-98fe-7612356dd673 rw [email protected]
loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> UEFI: American Megatrends v: B.70
date: 06/10/2020
Info: model: AMD Ryzen 5 3600XT bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4073 high: 4375 min/max: 2200/4635 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4365 2: 4375
3: 4223 4: 3800 5: 3800 6: 4371 7: 4373 8: 3647 9: 4375 10: 3605 11: 3800
12: 4151 bogomips: 91200
protection
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 29:00.0 chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.Org v: 21.1.5 with: Xwayland v: 22.1.6
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1080 s-dpi: 81 s-size: 803x343mm (31.61x13.50")
s-diag: 873mm (34.38")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX 1660
SUPER/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 5-4:2 chip-ID: 0d8c:0134 pcie:
gen: 3 class-ID: 0300 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 29:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media TONOR TC30 Audio Device type: USB
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-3:2 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 2.27 TiB used: 280.53 GiB (12.0%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
rev: 111110WD temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Seagate model: Portable
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0712 scheme: MBR
used: 280.53 GiB (60.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.57 GiB used: 2.93 GiB (18.8%)
System Temperatures: cpu: 74.9 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Processes: 378 Uptime: 3h 48m wakeups: 0 Memory: 15.57 GiB
used: 6.98 GiB (44.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1985
pm: pacman pkgs: 1973 libs: 523 tools: octopi,pamac,paru,yay pm: snap
pkgs: 12 Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-12-08
Last full system update: 2023-01-07
In case they were new, just trying to be a friendly help to them. Some people are new to forums and ignore instructions or just plain miss them. They select all text and remove it to add their issue not realizing they deleted instructions. Just trying to help them.
yea im new to forums, i think i asked once here. And it was the simplest of questions
No worries! Just try and make sure to attach your garuda-inxi
in the future. It helps the team and everyone be able to help you much faster having the inxi Happy Garuda-ing!
When a guest enters my house with shoes on, even though it says outside on the doormat:
Enter and be my guest, but please leave your shoes outside.
Which of us is then rude?
I was not rude, I could have locked or deleted the post directly.
Again, as reminder
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
Sorry SGS, wasn't trying to say you were being rude man. I was just trying to help; I've forgotten my inxi before, and since I'd been in those shoes, just posted to try and help. My comment was independent of yours.
BTW, for
It's not about simple or difficult, it's about information and what you've already tried to do to solve the problem.
I see many solutions there.
