I had a power cut today while my system was on
when i turned on my pc launching an application from my desktop caused the "open with" dialog to pop up
all the icons properties show "File type video/x-sgi-movie"
i tried creating new icons but they have the same issue
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=5853f345-c275-46ac-84e0-5de4868e2b5e rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1 dm: N/A
Mobo: ASUSTeK model: PRIME B450M-A II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2409
date: 12/02/2020
Info: model: AMD Ryzen 5 3500 bits: 64 type: MCP arch: Zen 2 gen: 3
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 3598 high: 3600 min/max: 2200/4120 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3593 5: 3600 6: 3600 bogomips: 43116
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 09:00.0 chip-ID: 1002:699f
class-ID: 0300 temp: 45.0 C
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) FULL HD
serial: <filter> built: 2016 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.2 renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 15.0.7 DRM 3.52 6.3.9-zen1-1-zen) direct-render: Yes
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
lanes: 8 bus-ID: 09:00.1 chip-ID: 1002:aae0 class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0c76:1694 class-ID: 0300
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
Local Storage: total: 465.76 GiB used: 189.1 GiB (40.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 37.9 C
ID-1: / raw-size: 349.78 GiB size: 349.78 GiB (100.00%)
used: 189.07 GiB (54.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 25 MiB (26.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 349.78 GiB size: 349.78 GiB (100.00%)
ID-4: /var/log raw-size: 349.78 GiB size: 349.78 GiB (100.00%)
ID-5: /var/tmp raw-size: 349.78 GiB size: 349.78 GiB (100.00%)
System Temperatures: cpu: 50.5 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1057
Processes: 312 Uptime: 26m wakeups: 0 Memory: available: 15.53 GiB
used: 5.86 GiB (37.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1644 pm: dpkg
pkgs: 0 pm: pacman pkgs: 1633 libs: 418 tools: octopi,paru pm: flatpak
pkgs: 11 Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.27
System install date: 2022-10-31
Last full system update: 2023-06-25
