Dbus-broker?!
so umm arch made dbus-broker their default implementation and i started to get these logs from jctl
Yan 10 13:21:37 AinGrace dbus-broker-launch[900]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.servic>
░░ Subject: Invalid service file
░░ Defined-By: dbus-broker
░░ Support: https://groups.google.com/forum/#!forum/bus1-devel
░░ A service file is a ini-type configuration file.
░░ It has one required section
░░ named [D-BUS Service]. The section contains the required key 'Name', which
░░ must be a valid D-Bus name that is unique across all service files. It also
░░ contains at least one of the two optional keys 'SystemdService' and 'Exec',
░░ as well as optionally the key 'User'. Exec must be a valid shell command and
░░ User must be a valid user on the system.
░░ A service file should be named after the D-Bus name it configures. That is
░░ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.
░░ For backwards compatibility, we only warn when files do not follow this
░░ convention when run as a user bus. The system bus considers this an error
░░ and ignores the service file.
Yan 10 13:21:37 AinGrace dbus-broker-launch[900]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.servi>
Yan 10 13:21:43 AinGrace dbus-broker-launch[1693]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.servi>
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bad4e716-211c-4572-b7c9-6588d8898c37 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LI_FX506LI
Mobo: ASUSTeK model: FX506LI v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX506LI.310 date: 11/26/2021
ID-1: BAT1 charge: 37.4 Wh (96.1%) condition: 38.9/48.2 Wh (80.7%)
volts: 12.5 min: 11.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 900 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 13d3:56a2
compositor: Hyprland driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia display-ID: 1
inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650 Ti/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.274 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 23.3.2-arch1.2
device-ID: 8086:9bc4 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1650 Ti driver: nvidia
v: 545.29.06 device-ID: 10de:1f95 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.3.2-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-3: C-Media USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0d8c:0012 class-ID: 0300
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 91.78 GiB (19.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 33.9 C
ID-1: / raw-size: 267.65 GiB size: 267.65 GiB (100.00%)
used: 91.75 GiB (34.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 25.6 MiB (26.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 267.65 GiB size: 267.65 GiB (100.00%)
ID-4: /var/log raw-size: 267.65 GiB size: 267.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 267.65 GiB size: 267.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C pch: 54.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Processes: 275 Uptime: 1h 27m wakeups: 1 Memory: total: 16 GiB
available: 15.46 GiB used: 4.83 GiB (31.3%) Init: systemd v: 255
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1901 libs: 460
tools: octopi,pamac,paru Shell: fish v: 3.7.0 default: Bash v: 5.2.21
Garuda (2.6.22-1):
System install date:     2023-10-04
Last full system update: 2024-01-10 ↻
should i expect my system nuking itself soon or im good?
Needed by systemd, so, you are fine.#
pacman -Qi dbus-broker-units
Version         : 35-2
Description     : Linux D-Bus Message Broker - Service units
Architecture    : x86_64
URL             : https://github.com/bus1/dbus-broker/wiki
Licenses        : Apache-2.0
Groups          : None
Provides        : dbus-units
Depends On      : dbus-broker
Optional Deps   : None
Required By     : systemd
Optional For    : None
Conflicts With  : dbus-daemon-units
Replaces        : None
Installed Size  : 0,00 B
Packager        : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date      : Fr 05 Jan 2024 15:45:05 CET
Install Date    : Mi 10 Jan 2024 12:53:50 CET
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signatur
My gut feeling is that if it hasn’t gave up the ghost yet, it won’t anytime soon.
I may or may not have a more informed opinion once I take the update too.
Though Invalid service file isn’t exactly saying “all systems are go”.
And I really, really love an error message telling me there’s an error but not where…
Like, “file not found”, and not the path of the file that is not found.
That’s good when I just typed a command in the shell, not so much when it comes from who knows where.
Oh well. /end-of-rant
Support: Redirecting to Google Groups
Jan 10 13:30:01 pro dbus-broker-launch[3143]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share/dbus->
Jan 10 13:30:09 pro lightdm[3366]: gkr-pam: unable to locate daemon control file
Jan 10 13:30:09 pro dbus-broker-launch[3723]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share/dbus-1>
Jan 10 13:30:09 pro dbus-broker-launch[3723]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share/dbus->
Ah… I missed part of the message
similar to 1966951 – Thunar duplicates dbus service name "org.freedesktop.FileManager1" (two or more file managers competing for the org.freedesktop.FileManager1 DBus name, first one wins.
edit: kde - Clean way to run proper file manager from Firefox on Linux - Unix & Linux Stack Exchange
(nevermind it says Firefox, it’s actually about DBus and Firefox is just a common instance)
Maybe the old DBus was silent about it?
I get this one instead
dbus-broker-launch[425]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
which if I recall correctly is not a problem but I’ll double check.
