I have issue with the davinci resolve package on aur. I tried to manually write the PCKGUILD file so it would download the newer version but that didn’t work (i only changed minor version form 0 to 3 which is not enough i had to learn). I now updated my system but not davinci resolve which has resulted in it completly stooping to work. And the biggest issue is that the maintainer is right no working on the package from what i know
is there a way how i could reinstall the old version of the package with the binarys already existing on my system ?
i tried your advice and now i have a new error
error: ‘/var/cache/pacman/pkg/davinci-resolve-18.1.4-1.1-x86_64.pkg.tar.zst’: invalid or corrupted package (PGP signature)
Hi @ANDO , actually i got a solution that is temp for now if you don’t have time to solve the issue , it does work for me when i encounter any brain melting issue with Davinci so far ,
The solution is to remove it completely from your system , yes (and anything related to it) and reinstall it ,
i would normaly do something similar but curently the davinci package is broken so ther is now way to install davinci via aur. I tried tinkering with the PKGBUILD but to no sucess. THe error exists cause the package is stil for version 18.6.0 but currently 18.6.2 is out
the way to “fix” this is to figure out the referid. which point to the right url on the blackmagic site. But i don’t know how to do that
