Davinci Resolve installed but does not launch
Hello,
I know it is a mess to install and make Davinci Resolve to run on any linux plateform. I have red the Davinci Resolve Arch wiki and checked all necessary drivers which are required. It seem to be all installed on my laptop. So Davinci Resolve was sucessfully installed from AUR but it doesn’t launch.
You can see here the log.
0x767ab93ac000 | Main                 | INFO  | 2024-11-03 17:24:57,680 | Running DaVinci Resolve v19.0.3.0005 (Linux/Clang x86_64)
0x767ab93ac000 | Main                 | INFO  | 2024-11-03 17:24:57,680 | BMD_BUILD_UUID 8ffcf7a4-ad3c-4ae0-b18e-e558ac435275
0x767ab93ac000 | Main                 | INFO  | 2024-11-03 17:24:57,680 | BMD_GIT_COMMIT 67f92ed0dbc9aa2b4da3ccfaba0b32405cef11ac
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,680 | Starting GPUDetect 1.2_6-a2
0x767ab93ac000 | GPUDetect            | ERROR | 2024-11-03 17:24:57,820 | No Main Display GPU found and no monitors found to match, defaulting to gpu:95a5b4ea.f91e8f0c.
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 | Done in 139 ms.
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 | Detected System:
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 |   - OS: Linux Garuda
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 |   - Model: MEDION NPxxRNA
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 |   - System ID: a211d950b88448d589cf5cb403dd2ed8
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 |   - CPU: 12th Gen Intel Core i5-12450H, 12 threads, x86-64
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 |   - RAM: 2.5 GiB used of 31.0 GiB
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 | Detected 1 GPUs:
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 |   - "NVIDIA GeForce RTX 2050" (gpu:95a5b4ea.f91e8f0c) <- Main Display GPU
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 |     Discrete, 3.7 GiB VRAM, PCI:1:0.0
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 |     Matches: CUDA, NVML, OpenCL, XOrg
0x767ab93ac000 | GPUDetect            | INFO  | 2024-11-03 17:24:57,820 | Detected 1 monitors:
0x767ab93ac000 | Main.GPUConfig       | INFO  | 2024-11-03 17:24:57,820 | Compute API set to automatic, defaulting to CUDA.
0x767ab93ac000 | Main.GPUConfig       | INFO  | 2024-11-03 17:24:57,820 | Selected compute API: CUDA
0x767ab93ac000 | Main.GPUConfig       | INFO  | 2024-11-03 17:24:57,820 | Automatic GPU Selection:
0x767ab93ac000 | Main.GPUConfig       | INFO  | 2024-11-03 17:24:57,820 |   - "NVIDIA GeForce RTX 2050" (gpu:95a5b4ea.f91e8f0c)
0x767ab93ac000 | IO                   | INFO  | 2024-11-03 17:24:57,820 | RED InitializeSdk with library path at /opt/resolve/libs
0x767ab93ac000 | IO                   | INFO  | 2024-11-03 17:24:57,966 | R3DAPI 8.5.1-53601 (20240308 Lx64S) R3DSDK 8.5.1-53601 (20240308 Lx64D C3B1) RED CUDA 8.5.1-53598 (20240308) [/opt/resolve/libs/] init is successful
0x767ab93ac000 | Main                 | INFO  | 2024-11-03 17:24:57,966 | 0 RED rocket cards available
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
0x767ab93ac000 | Main                 | INFO  | 2024-11-03 17:24:57,966 | Decklink model name: '', version: ''
0x767ab93ac000 | DVIP                 | INFO  | 2024-11-03 17:24:57,966 | DVIP release/19.0.3 build 2 (1d2febb1ee4fe874652901b728218e741ecebe06). Release, version 19.0.3.
0x767a45200000 | IO                   | INFO  | 2024-11-03 17:24:57,967 | Using DNxHR library v2.7.5.873r
0x767a43e00000 | SyManager            | ERROR | 2024-11-03 17:24:58,039 | GetProjectLibraries() - Access token is empty
0x767a45c00000 | Fusion               | INFO  | 2024-11-03 17:24:58,157 | Fusion Build: 38f265c7_0003 (Oct 11 2024 12:27:58)
==========[CRASH DUMP]==========
#TIME Sun Nov  3 17:24:58 2024 - Uptime 00:00:00 (hh:mm:ss)
#PROGRAM_NAME DaVinci Resolve v19.0.3.0005 (Linux/Clang x86_64)
#BMD_ARCHITECTURE x86_64
#BMD_BUILD_UUID 8ffcf7a4-ad3c-4ae0-b18e-e558ac435275
#BMD_GIT_COMMIT 67f92ed0dbc9aa2b4da3ccfaba0b32405cef11ac
#BMD_UTIL_VERSION 19.0.3.0005
#OS Linux
/opt/resolve/bin/resolve() [0x4e149b9]
/opt/resolve/bin/resolve() [0x4e13d90]
/usr/lib/libc.so.6(+0x3d1d0) [0x767abfb491d0]
/usr/lib/libc.so.6(+0x963f4) [0x767abfba23f4]
/usr/lib/libc.so.6(gsignal+0x20) [0x767abfb49120]
/usr/lib/libc.so.6(abort+0xdf) [0x767abfb304c3]
/opt/resolve/bin/../libs/libQt5Core.so.5(+0x1821c6) [0x767a9fd821c6]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZNK14QMessageLogger5fatalEPKcz+0xbd) [0x767a9fd6ea5d]
/opt/resolve/bin/../libs/libQt5Gui.so.5(_ZN22QGuiApplicationPrivate25createPlatformIntegrationEv+0x1d4c) [0x767aa231e22c]
/opt/resolve/bin/../libs/libQt5Gui.so.5(_ZN22QGuiApplicationPrivate21createEventDispatcherEv+0x1b) [0x767aa231ed3b]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN23QCoreApplicationPrivate4initEv+0x5d4) [0x767a9ff5c984]
/opt/resolve/bin/../libs/libQt5Gui.so.5(_ZN22QGuiApplicationPrivate4initEv+0x19) [0x767aa2318319]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN19QApplicationPrivate4initEv+0x9) [0x767ad3364f09]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN12QApplicationC2ERiPPci+0xa9) [0x767ad3364ec9]
/opt/resolve/bin/resolve() [0x2870ae8]
/opt/resolve/bin/resolve() [0x281a09b]
/opt/resolve/bin/resolve() [0x28147be]
/usr/lib/libc.so.6(+0x25e08) [0x767abfb31e08]
/usr/lib/libc.so.6(__libc_start_main+0x8c) [0x767abfb31ecc]
/opt/resolve/bin/resolve() [0x2812eab]
Signal Number = 6
0x767a38000000 | Fusion               | INFO  | 2024-11-03 17:24:58,162 | fusionsystem: = "/opt/resolve/libs/Fusion/libfusionsystem.so"
0x767a38000000 | Fusion               | INFO  | 2024-11-03 17:24:58,165 | FusionLibs: = "/opt/resolve/libs/Fusion/"
0x767a38000000 | Fusion               | INFO  | 2024-11-03 17:24:58,165 | UserData:   = "/home/abel/.local/share/DaVinciResolve/Fusion"
0x767a38000000 | Fusion               | INFO  | 2024-11-03 17:24:58,165 | Profiles:   = "UserData:Profiles/"
0x767a45200000 | IO                   | INFO  | 2024-11-03 17:24:58,166 | NVDEC is using upto (474) MB
0x767a45200000 | IO                   | INFO  | 2024-11-03 17:24:58,173 | NVDEC decodes VP9, chroma 4:2:0, bitdepth 8, upto 8192 x 8192
0x767a45200000 | IO                   | INFO  | 2024-11-03 17:24:58,180 | NVDEC decodes VP9, chroma 4:2:0, bitdepth 10, upto 8192 x 8192
0x767a45200000 | IO                   | INFO  | 2024-11-03 17:24:58,186 | NVDEC decodes AV1, chroma 4:2:0, bitdepth 8, upto 8192 x 8192
0x767a45200000 | IO                   | INFO  | 2024-11-03 17:24:58,192 | NVDEC decodes AV1, chroma 4:2:0, bitdepth 10, upto 8192 x 8192
0x767a45200000 | IO                   | INFO  | 2024-11-03 17:24:58,193 | Nvidia : driverVer(194), SDK(12:2), isLegacy(0)
0x767ab93ac000 | CrashReport          | ERROR | 2024-11-03 17:24:58,389 | Compress() : Failed to add file:/home/abel/.local/share/DaVinciResolve/configs/UI.preset to archive.
0x767ab93ac000 | CrashReport          | ERROR | 2024-11-03 17:24:58,389 | Compress() : Failed to add file:/home/abel/.local/share/DaVinciResolve/configs/config.user.xml to archive.
ActCCMessage Already in Table: Code= c005, Mode= 13, Level=  1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c006, Mode= 13, Level=  1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c007, Mode= 13, Level=  1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= 2282, Mode=  0, Level=  0, CmdKey= 8, Option= 0
There is one line that seems to be the problem (but they might be more). How could I fix that ?
It makes no sense to post logs of error messages externally if they are deleted after 29 days.
Later readers looking for help with the same problem will then no longer be able to see whether it is identical to theirs. That’s why I added it to your post.
  Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=973c836c-a591-4377-a359-03b86d2756d9 rw rootflags=subvol=@
  Desktop: GNOME v: 47.1 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
  Type: Laptop System: MEDION product: Crawler E30e v: N/A
  Mobo: MEDION model: NPxxRNA v: 1.0 serial: <superuser required>
    part-nu: ML-210008 40090164 uuid: <superuser required> UEFI: INSYDE
    v: 1.07.03RME1_00015 date: 10/05/2023
  ID-1: BAT0 charge: 25.4 Wh (47.7%) condition: 53.2/52.5 Wh (101.3%)
    volts: 14.4 min: 15.4 model: Notebook BAT type: Li-ion serial: <filter>
  Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
    microcode: 0x434
  Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
    st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
    KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 829 min/max: 400/4400:3300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 829 2: 829 3: 829 4: 829 5: 829 6: 829 7: 829
    8: 829 9: 829 10: 829 11: 829 12: 829 bogomips: 59904
  Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-2,HDMI-A-1,HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:46a3 class-ID: 0300
  Device-2: NVIDIA GA107 [GeForce RTX 2050] vendor: CLEVO/KAPOK
    driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s
    lanes: 8 link-max: lanes: 16 ports: active: none empty: DP-1
    bus-ID: 01:00.0 chip-ID: 10de:25ad class-ID: 0300
  Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:2 chip-ID: 04f2:b729
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0b07 built: 2021 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46a3 memory: 15.16 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.3.295 layers: 4 device: 0 type: integrated-gpu name: Intel
    Graphics (ADL GT2) driver: mesa intel v: 24.2.6-arch1.1
    device-ID: 8086:46a3 surfaces: xcb,xlib,wayland device: 1
    type: discrete-gpu name: NVIDIA GeForce RTX 2050 driver: nvidia
    v: 565.57.01 device-ID: 10de:25ad surfaces: xcb,xlib,wayland device: 2
    v: 24.2.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
    bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:2291 class-ID: 0403
  API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
  Local Storage: total: 476.94 GiB used: 26.59 GiB (5.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Foresee model: XP2000F512G
    lanes: 4 tech: SSD serial: <filter> fw-rev: V1223J0T temp: 30.9 C
  ID-1: / raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
    used: 15.57 GiB (26.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 417.84 GiB size: 410.22 GiB (98.17%)
    used: 11.02 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-4: /var/log raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
  ID-5: /var/tmp raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.04 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 33.0 C mobo: N/A
  Memory: total: 32 GiB note: est. available: 31.04 GiB used: 2.81 GiB (9.1%)
  Processes: 348 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.36 GiB services: gsd-power,
  Packages: pm: pacman pkgs: 1350 libs: 429 tools: paru Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
    running-in: gnome-terminal inxi: 3.3.36
  System install date:     2024-11-02
  Last full system update: 2024-11-03
I understand perfectly, sorry ! I am not really used with forums any more
I finally received the solution on the telegram discussion group.
Davinci Resolve successfully launched when I logged Xorg Session instead of Wayland.
