Hello Garuda users.
So I downloaded and installed Resolve from the main website. It installed just fine but when I open it never actually starts.
Using ‘sudo pacman -S davinci-resolve’ (as suggested in How to install davinci resolve in garuda and run without error - #3) ends up showing: “error: target not found: davinci-resolve”.
Any ideas?
Kernel: 6.5.6-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=daeaec07-4727-48f9-a0c8-0979200313c4 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: X570 I AORUS PRO WIFI v: -CF
Mobo: Gigabyte model: X570 I AORUS PRO WIFI serial: <superuser required>
UEFI: American Megatrends LLC. v: F37e date: 08/09/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3545 high: 3755 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3755 2: 3697
3: 3595 4: 3400 5: 3598 6: 3630 7: 3400 8: 3400 9: 3576 10: 3652 11: 3606
12: 3590 13: 3400 14: 3400 15: 3623 16: 3400 bogomips: 108799
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti] vendor: eVga.com.
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.0 chip-ID: 10de:1e04 class-ID: 0300
Screen-1: 0 s-res: 6000x1440 s-dpi: 108 s-size: 1411x342mm (55.55x13.46")
s-diag: 1452mm (57.16")
Monitor-1: DP-2 pos: right res: 2560x1440 dpi: 109
Monitor-2: DP-4 pos: primary,left res: 3440x1440 dpi: 109
size: 798x335mm (31.42x13.19") diag: 865mm (34.07") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
memory: 10.74 GiB
API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2080 Ti driver: nvidia v: 535.113.01 device-ID: 10de:1e04
surfaces: xcb,xlib
Device-1: NVIDIA TU102 High Definition Audio vendor: eVga.com.
bus-ID: 0a:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-2: Creative Sound Blaster X3
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-4:5 chip-ID: 041e:3264
API: ALSA v: k6.5.6-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 8087:0029
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.84 TiB used: 392.78 GiB (20.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD BLACK SN850 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 613200WD temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 model: PCIe SSD size: 953.87 GiB
tech: SSD serial: <filter> fw-rev: ECFM12.2 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 545.48 GiB size: 545.48 GiB (100.00%)
used: 392.75 GiB (72.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:7
used: 26.8 MiB (27.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 545.48 GiB size: 545.48 GiB (100.00%)
ID-4: /var/log raw-size: 545.48 GiB size: 545.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 545.48 GiB size: 545.48 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.26 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.5 C mobo: 40.0 C gpu: nvidia temp: 53 C
Fan Speeds (rpm): fan-1: 1073 gpu: nvidia fan: 32%
Processes: 372 Uptime: 9m wakeups: 1 Memory: total: 32 GiB
available: 31.26 GiB used: 6.65 GiB (21.3%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1517 libs: 456 tools: octopi,pamac,paru
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-08-24
Last full system update: 2023-10-11
