DaVinci Resolve 17 Doesn't start at all
Reading the arch wiki on davinci
Have you tried installing it as a workaround in wine
hello am pardesi cat after did a research i finally able to fix the problem
oke 1 st you have to uninstall ur nvidia/amd -mesa drivers then simply install
" libxcrypt-compat "
type in console sudo pacman -S libxcrypt-compat
I had the same issue but I thought this is AMD GPU related.
But yes you need to get the crypt file for the GPU ... I wonder if it is the same error on an nVidia GPU :thinking:
EDIT: and Resolve tells you that the file is missing (at least in my case)...
BruceLakeriver
i did it on nvidia 1050ti
what i did is i just located where its installed then i tried the run app in terminal where i saw whats actual error then i headed to internet after some research i found its included in libxcrypt-compat so i did and it worked :slight_smile:
I'm glad to hear that :smiley:
It some cases no error message gets prompted. Those users are frankly clueless. :pensive:
