Hi there. Sometimes when we open other external applications they think that a system theme is clear/white by default. So if we can't setup those external applications we will have a white theme forever for those apps. What I want to know is how can we say that the current theme is dark and the value isn't system or clear whithout installing any software, but by only defining system wide variable that the current theme is dark. Perhaps a config property inside a text value can be set to say that ?
Kernel: 5.18.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=fdd54764-dc63-4cb3-8f1d-285b3a23a1a2 rw rootflags=subvol=@
quiet
cryptdevice=UUID=ad284741-3436-4f92-a2c7-fbcc5651743c:luks-ad284741-3436-4f92-a2c7-fbcc5651743c
root=/dev/mapper/luks-ad284741-3436-4f92-a2c7-fbcc5651743c quiet splash
resume=/dev/mapper/luks-8305d0a2-1387-4295-af6b-7e3ae209092b loglevel=3
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop System: Dell product: Inspiron 5680 v: 2.4.0
Mobo: Dell model: 0M8K4M v: A00 serial: <superuser required> UEFI: Dell
v: 2.4.0 date: 06/16/2020
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2497 high: 2900 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2900 2: 2900 3: 2600
4: 2311 5: 2300 6: 2300 7: 2300 8: 2302 9: 2273 10: 2300 11: 2878
12: 2600 bogomips: 76799
Type: l1tf
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Dell driver: nouveau
v: kernel non-free: 515.xx+ status: current (as of 2022-06) arch: Pascal
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1c03
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa gpu: nouveau display-ID: :0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: LG (GoldStar) 23MP55
built: 2014 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: NV136 v: 4.3 Mesa 22.1.2 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Dell
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f1
Sound Server-1: ALSA v: k5.18.7-zen1-1-zen running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-12:4
chip-ID: 0cf3:e009 class-ID: e001
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
port: f020 bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 1.24 TiB used: 143.91 GiB (11.3%)
model: WDS240G2G0A-00JH30 size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0400
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A02 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: SK Hynix model: SC311 SATA 128GB
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0P10 scheme: GPT
ID-1: / raw-size: 206.31 GiB size: 206.31 GiB (100.00%)
used: 13.97 GiB (6.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ad284741-3436-4f92-a2c7-fbcc5651743c
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 206.31 GiB size: 206.31 GiB (100.00%)
ID-4: /var/log raw-size: 206.31 GiB size: 206.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 206.31 GiB size: 206.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
mapped: luks-8305d0a2-1387-4295-af6b-7e3ae209092b
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nouveau temp: 40.0 C
Fan Speeds (RPM): cpu: 1179 fan-2: 984 gpu: nouveau fan: 1015
Processes: 302 Uptime: 2h 41m wakeups: 0 Memory: 15.42 GiB
used: 2.71 GiB (17.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1359 lib: 367
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-07-01
Last full system update: 2022-07-02
