I have updated to the latest firedragon 101.0.1
Dark Reader plugin is not working properly anymore. When you click on the dark reader icon at the top left. It show as "loading please wait". When I got to any page it is white instead of black. I really miss this.
Garuda-Inxi
Kernel: 5.18.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=00b33177-335b-466d-8a5b-e5bad5669f19 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 24.5 Wh (61.6%) condition: 39.8/51.6 Wh (77.2%)
volts: 11.1 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check
bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1314 high: 1800 min/max: 800/4500 base/boost: 2475/8300
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 1800 2: 1800 3: 1800 4: 1633 5: 1144 6: 800
7: 800 8: 800 9: 800 10: 800 11: 1800 12: 1800 bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:5
chip-ID: 04f2:b695 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
Sound Server-1: ALSA v: k5.18.7-zen1-1-zen running: yes
vendor: Micro-Star MSI driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 1.38 TiB lvm-free: 1.51 GiB used: 580.11 GiB (41.2%)
model: PC SN520 SDAPNUW-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20140000 temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 234d 7h cycles: 3,832
read-units: 43,801,208 [22.4 TB] written-units: 38,222,495 [19.5 TB]
model: WD10JPVX-60JC3T0 family: Blue Mobile size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 1A01 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 344d 4h cycles: 7679
Old-Age: g-sense error rate: 337 write error rate: 100 threshold: 100
ID-1: / raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
used: 88.2 GiB (60.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 557 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.47 GiB used: 322.2 MiB (2.0%)
System Temperatures: cpu: 47.0 C pch: 55.0 C mobo: N/A
Processes: 364 Uptime: 1d 5h 29m wakeups: 5 Memory: 15.47 GiB
used: 3.93 GiB (25.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1909
lib: 544 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-01-25
Last full system update: 2022-06-29
Failed units: pacman-files.service
