i tried "flameshot gui" command in konsole it works, only from this shortcut it is not working
did i miss any steps?
edit: other triggers that didn't work: meta+print
triggers that worked: ctrl+print, ctrl+shift+print
so why i don't use them? >> i need all of them for different kind of screenshot commands.
You can actually add Flameshot another way from within that shortcut menu you have open there. Click "Add Application" and either search for Flameshot or find it in the "Graphics" folder. That will add Flameshot to the Applications menu.
Select Flameshot from the menu and you can assign the print key in a custom shortcut.
