When using the Sweet cursor, which is the default, it works everywhere. I've installed the LyraR cursor, and I noticed that when near a dock (eg. Latte, Conky), on Title Bars and also Java applications (eg. Minecraft) the cursor changes to the Adwaita theme. Any help?
garuda-inxi here:
Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=952017aa-dcff-42ae-8a0e-d05399391137 rw rootflags=subvol=@
Mobo: ASUSTeK model: PRIME A520M-A v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 1804
date: 02/01/2021
Info: model: AMD Ryzen 7 PRO 4750G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3084 high: 3839 min/max: 1400/4454 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3238 2: 2994
3: 2982 4: 2989 5: 2993 6: 3148 7: 2994 8: 2994 9: 2994 10: 2992 11: 2995
12: 3305 13: 3839 14: 2922 15: 2974 16: 2994 bogomips: 114980
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 3
active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 07:00.0 chip-ID: 1002:1636
Device-2: Microdia Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 0c45:64ab class-ID: 0e02
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 mapped: HDMI-A-1 model: Philips PHL 243V7
serial: <filter> built: 2020 res: 1920x1080 dpi: 93 gamma: 1.2
size: 527x296mm (20.7x11.7") diag: 604mm (23.8") ratio: 16:9 modes:
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.13-zen1-1-zen LLVM 13.0.1)
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK PRIME B450M-A
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.48 running: yes
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
bus-ID: 5-1:2 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp7s0f4u1 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 0a12:0001 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.0 sub-v: 22bb hci-v: 4.0 rev: 22bb
Info: acl-mtu: 310:10 sco-mtu: 64:8 link-policy: rswitch hold sniff park
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Local Storage: total: 1.13 TiB used: 339.31 GiB (29.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Burst size: 223.57 GiB
serial: <filter> rev: 61.3 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD110
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A8R0
scheme: MBR
ID-1: / raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
used: 56.41 GiB (26.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-3: /var/log raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-4: /var/tmp raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-1: swap-1 type: zram size: 15 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 20.0 C
Processes: 436 Uptime: 38m wakeups: 0 Memory: 15 GiB used: 5.38 GiB (35.9%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1812 lib: 519 Shell: fish v: 3.3.1 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-02-20
Last full system update: 2022-03-12
Snapshots: Timeshift
Failed units: shadow.service
