Custom assembly of Garuda bspwm. The post has been collected. But… I have questions. There is a problem with lingtdm, which does not work automatically when the system boots. You need to enable service manually. I tried to make symlinks in the /etc/systemd/system/ directory. This does not work. How can I fix this? Also, the hook is not initialized after the system boots. What’s the right place to put them?
“sudo systemctl enable lightdm” not work?
https://wiki.archlinux.org/title/LightDM#Enabling_LightDM
And where is your garuda-inxi?
No. It works. You just have to do it manually every time. Automatic does not work
Kernel: 6.8.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: i3 v: 4.23 Distro: Garuda base: Arch Linux
Type: Laptop System: Dell product: Dell G15 5520 v: N/A
Mobo: Dell model: 05J7DY v: A07 serial: <superuser required> UEFI: Dell
v: 1.17.0 date: 04/17/2023
ID-1: BAT0 charge: 84.3 Wh (100.0%) condition: 84.3/84.3 Wh (100.0%)
volts: 12.5 min: 11.4 model: BYD DELL M59JH29 status: full
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 1.2 MiB L2: 11.5 MiB
L3: 24 MiB
Speed (MHz): avg: 627 high: 1300 min/max: 400/2300:1700 cores: 1: 711
2: 400 3: 400 4: 400 5: 400 6: 400 7: 948 8: 400 9: 400 10: 400 11: 722
12: 400 13: 1297 14: 1156 15: 400 16: 1300 17: 400 18: 400 19: 1210
20: 400 bogomips: 107520
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.2 bus-ID: 00:02.0
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 550.67 arch: Ampere bus-ID: 01:00.0
bus-ID: 3-5:3
Display: x11 server: X.Org v: 21.1.12 driver: X:
loaded: modesetting,nvidia unloaded: nouveau dri: iris gpu: i915
resolution: 1920x1080~165Hz
API: Vulkan v: 1.3.279 drivers: intel,nvidia,llvmpipe surfaces: xcb,xlib
devices: 3
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
API: ALSA v: k6.8.4-zen1-1-zen status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: PipeWire v: 1.0.4 status: active
iso-profiles master ?12 ~8 -1 0s vir0id / android 9:56:34 AM
root=UUID=66b6ae15-8761-4707-b5a6-0d26130f258a rw rootflags=subvol=@
Desktop: i3 v: 4.23 with: polybar tools: avail: i3lock,xautolock vt: 7
Mobo: Dell model: 05J7DY v: A07 serial: <superuser required> part-nu: 0B56
uuid: <superuser required> UEFI: Dell v: 1.17.0 date: 04/17/2023
volts: 12.5 min: 11.4 model: BYD DELL M59JH29 type: Li-poly serial: <filter>
status: full
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
microcode: 0x432
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 788 high: 1300 min/max: 400/2300:1700 scaling:
driver: intel_pstate governor: powersave cores: 1: 590 2: 400 3: 952 4: 400
5: 400 6: 1109 7: 401 8: 1076 9: 632 10: 400 11: 843 12: 400 13: 1185
14: 1130 15: 400 16: 1155 17: 1300 18: 1300 19: 1299 20: 400
bogomips: 107520
driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
built: 2021-22+ ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 ports: active: none empty: HDMI-A-1,eDP-2
bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 0c45:6d1d
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.12 compositor: Picom v: git-89c2c
driver: X: loaded: modesetting,nvidia unloaded: nouveau
Monitor-1: eDP-1 model: LG Display 0x06e2 built: 2021 res: 1920x1080
hz: 165 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 24.0.4-arch1.2
device-ID: 8086:46a6 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.67
device-ID: 10de:2560 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.4-arch1.2 (LLVM
chip-ID: 8086:51c8 class-ID: 0401
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
API: ALSA v: k6.8.4-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-2: Realtek Killer E2600 GbE vendor: Dell driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3b:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF: enp59s0 state: down mac: <filter>
Info: services: httpd, NetworkManager, proftpd, systemd-timesyncd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Local Storage: total: 1.1 TiB used: 790.89 GiB (69.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9B1 NVMe 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 46305039 temp: 45.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: Flash Drive FIT
size: 119.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 128 GiB size: 128 GiB (100.00%) used: 60.49 GiB (47.3%)
ID-2: /boot/efi raw-size: 950 MiB size: 948.1 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 128 GiB size: 128 GiB (100.00%)
used: 60.49 GiB (47.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 128 GiB size: 128 GiB (100.00%)
ID-5: /var/tmp raw-size: 128 GiB size: 128 GiB (100.00%)
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.31 GiB used: 1.97 GiB (12.8%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20
System Temperatures: cpu: 56.0 C mobo: 55.0 C
Fan Speeds (rpm): cpu: 1637 fan-2: 1876
Memory: total: 16 GiB note: est. available: 15.31 GiB used: 4.66 GiB (30.4%)
Processes: 428 Power: uptime: 3h 58m states: freeze,mem,disk
suspend, test_resume image: 6.1 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1772 libs: 445 tools: octopi,pacseek,paru
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Zsh v: 5.9
running-in: kitty inxi: 3.3.33
Garuda (2.6.24-1):
System install date: 2024-03-23
Last full system update: 2024-04-08
Is partially upgraded: Yes
Relevant software: snapper NetworkManager dracut(custom) mkinitcpio nvidia-dkms
Without garuda-inxi this request will be moved to 412 Precondition Failed
Unfortunately, BSPWM is no longer supported due to a lack of maintainers.
) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
@igorjoxa1118 I fixed it for you.
I think he is trying to build it himself from scratch…
