Here is my garuda-inxi:
[nicolo@nicolo-pc ~]$ garuda-inxi
Kernel: 5.15.74-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=10eff176-0f05-40d0-8036-ea2504cc29cc rw rootflags=subvol=@
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: SAMSUNG product: QX310/QX410/QX510/SF310/SF410/SF510
v: 05MX serial: <superuser required> Chassis: type: 9
Mobo: SAMSUNG model: QX310/QX410/QX510/SF310/SF410/SF510 v: 05MX
serial: <superuser required> BIOS: American Megatrends
v: 05MX.M008.20110525.SCY date: 05/25/2011
ID-1: BAT1 charge: 33.7 Wh (82.0%) condition: 41.1/61.0 Wh (67.3%)
volts: 11.5 min: 11.1 model: SAMSUNG Electronics type: Li-ion serial: N/A
Info: model: Intel Core i5 M 480 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2103 high: 2373 min/max: 1199/2667 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1997 2: 2373
3: 2009 4: 2035 bogomips: 21279
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
prctl and seccomp
Device-1: Intel Core Processor Integrated Graphics vendor: Samsung Co
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010
ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Device-2: NVIDIA GT218M [GeForce 310M] vendor: Samsung Co driver: nouveau
v: kernel non-free: series: 340.xx status: legacy (EOL) last:
release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
built: 2006-13 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: none
off: VGA-2 empty: none bus-ID: 01:00.0 chip-ID: 10de:0a70 class-ID: 0302
temp: 66.0 C
Device-3: Silicon Motion WebCam SCB-0370N type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 2232:1001 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting,nouveau alternate: fbdev,intel,nv,vesa
dri: crocus,nouveau gpu: i915,nouveau display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 pos: primary model: Seiko Epson 0x3355 built: 2010
res: 1366x768 hz: 60 dpi: 118 gamma: 1.2 size: 293x165mm (11.54x6.5")
diag: 336mm (13.2") ratio: 16:9 modes: 1366x768
Monitor-2: VGA-2 mapped: VGA-1-2 note: disabled size-res: N/A modes:
max: 1024x768 min: 640x480
OpenGL: renderer: Mesa Intel HD Graphics (ILK) v: 2.1 Mesa 22.2.1
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Samsung Co driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Samsung Co
bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
Sound API: ALSA v: k5.15.74-1-lts running: yes
Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Askey
bus-ID: 02:00.0 chip-ID: 14e4:4727 class-ID: 0280
Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB]
vendor: Samsung Co driver: sky2 v: 1.30 pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: b000 bus-ID: 03:00.0 chip-ID: 11ab:4381 class-ID: 0200
Local Storage: total: 232.89 GiB used: 73.86 GiB (31.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 750 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-1: / raw-size: 169.41 GiB size: 169.41 GiB (100.00%) used: 73.86 GiB
(43.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 169.41 GiB size: 169.41 GiB (100.00%) used: 73.86
GiB (43.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 169.41 GiB size: 169.41 GiB (100.00%) used: 73.86
ID-4: /var/tmp raw-size: 169.41 GiB size: 169.41 GiB (100.00%) used: 73.86
ID-1: swap-1 type: zram size: 3.62 GiB used: 234 MiB (6.3%) priority: 100
System Temperatures: cpu: 71.0 C mobo: N/A gpu: nouveau temp: 66.0 C
Processes: 245 Uptime: 17m wakeups: 1 Memory: 3.63 GiB used: 2.13 GiB
(58.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1378 libs: 357
tools: pamac,paru,yay Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-10-17
Last full system update: 2022-10-19 ↻
I have a problem: my mouse cursor (the "hand" one) (chicago95) is "strange" in some apps, and working in some other apps.
In some apps it's the other one, but on other ones it's adwaita...
the apps where it shows adwaita are: spotify, opera, chrome
Video example:
(https://streamable.com/0zv9iu) i did it this way cause I can't embed videos
I don't know if you can understand my english, and that's because I am italian.
But if you have any english-related corrections, tell me.
