Current situation: Wayland x Draconized KDE x Nvidia
╭─ftx@FTX in ~ via  v3.10.4 took 4ms
╰─λ garuda-inxi
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b5ace5ad-afa1-4d36-b45e-80bf0bd9dcc4 rw rootflags=subvol=@
quiet
cryptdevice=UUID=4f4d0d43-dcd9-4fd0-ae1d-de296b163620:luks-4f4d0d43-dcd9-4fd0-ae1d-de296b163620
root=/dev/mapper/luks-4f4d0d43-dcd9-4fd0-ae1d-de296b163620 quiet splash
Type: Desktop System: Dell product: Inspiron 5680 v: 2.4.0
Mobo: Dell model: 0M8K4M v: A00 serial: <superuser required> UEFI: Dell
v: 2.4.0 date: 06/16/2020
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 926 high: 1218 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 900 8: 900 9: 900 10: 1218 11: 900 12: 900
bogomips: 76799
Type: l1tf
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Dell driver: nvidia
v: 515.43.04 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Pascal pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.20x11.50")
s-diag: 590mm (23.24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 515.43.04 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Dell
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-12:4
chip-ID: 0cf3:e009 class-ID: e001
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
port: f020 bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 1.24 TiB used: 173.11 GiB (13.6%)
model: WDS240G2G0A-00JH30 size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0400
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A02 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: SK Hynix model: SC311 SATA 128GB
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0P10 scheme: GPT
used: 45.26 GiB (20.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-4f4d0d43-dcd9-4fd0-ae1d-de296b163620
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 15.42 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 48 C
Fan Speeds (RPM): cpu: 976 fan-1: 1172 gpu: nvidia fan: 49%
Processes: 336 Uptime: 20m wakeups: 0 Memory: 15.42 GiB
used: 4.02 GiB (26.0%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1592 lib: 422 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date:     2022-05-21
Last full system update: 2022-05-29 ↻
Failed units:            systemd-coredump@0-55400-0.service
Hello to everyone! I want to know the current situation of Garuda Draconized running on Wayland. The only post I found here is locked and the last entry was added in March 8th. I found this on the web:
I'm using Nvidia and I read about their improvements for Wayland:
I'm wondering what people from Garuda will do about Wayland and KDE Plasma. That's, I want to know if you guys have any news. Perhaps this post can be used to track and keep people updated about the subject?
PS: What kind of help we can give in order to speed up the process of allowing Garuda Draconized to use Wayland.
Thanks!
Waiting until the bugs are worked out :slight_smile: since we don’t develop KDE ourselves it’s mostly down to that.
Well I guess all you can do is using Wayland and reporting eventual bugs. However, there is already a list of known showstoppers which will eventually be worked on by KDE devs. This also reflects the current state quite well.
https://community.kde.org/Plasma/Wayland_Showstoppers
If none of those issues are actually a concern of yours, this shouldn’t stop you from doing Wayland adventures yourself :wink:
I am already using wayland on Dragonized. the only issue OOB related to Dragonized setup is that Optimus manager does not support wayland.
