Ctrl + Alt +T not working?
Hello all. I've screwed up my "Open Konsole" shortcut but I'm not sure how I did it. I thought I'd fix it in Settings > Shortcuts, but When I saw it I thought I may have deleted a whole Konsole section by mistake so, I did a fresh install in a VM and took a look at Settings > Shortcuts. I don't see a Konsole section. Under Custom, I do see a Konsole shortcut under Examples, but it's not enabled. Nevertheless, Ctrl + Alt + T opens a Konsole in the VM.
I'm pretty sure I could fix it by adding a new shortcut, but I was wondering if anyone might know how to fix it properly, the way it was. How was the shortcut originally configured, if anyone might know. This might also give me a clue as to what I may have done wrong. Thanks for any help.
Ooops...forgot my
 ╭─user@maruda in ~
 ╰─λ garuda-inxi
  Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=420f9c9f-c154-4985-9f0f-c412b1ae5b71 rw rootflags=subvol=@
  Type: Laptop System: LENOVO product: 427639U v: ThinkPad W520
  Mobo: LENOVO model: 427639U serial: <superuser required> UEFI: LENOVO
    v: 8BET62WW (1.42 ) date: 07/26/2013
  Info: model: Intel Core i7-2820QM bits: 64 type: MT MCP arch: Sandy Bridge
    family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1300 high: 2897 min/max: 800/3400 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2230 2: 855 3: 797
    4: 2897 5: 1231 6: 798 7: 797 8: 798 bogomips: 36682
  Type: l1tf
    vendor: Lenovo driver: i915 v: kernel ports: active: LVDS-1 empty: VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
  Device-2: NVIDIA GF108GLM [Quadro 1000M] vendor: Lenovo driver: nvidia
    v: 390.151 alternate: nouveau,nvidia_drm non-free: 390.xx+
    status: legacy-active (EOL late 2022) arch: Fermi pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0dfa
  Device-3: Chicony Lenovo Integrated Camera (0.3MP) type: USB
    driver: uvcvideo bus-ID: 1-1.6:5 chip-ID: 04f2:b217 class-ID: 0e02
    compositor: kwin_x11 driver: X: loaded: modesetting gpu: i915
  Monitor-1: LVDS-1 model: Lenovo 0x40b2 built: 2009 res: 1920x1080 hz: 60
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
    v: 3.3 Mesa 22.0.4 compat-v: 3.1 direct render: Yes
    vendor: Lenovo ThinkPad T520 driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF108 High Definition Audio vendor: Lenovo
    bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
  Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
  Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
    driver: e1000e v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502
  Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
    chip-ID: 8086:0085 class-ID: 0280
  Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
    bus-ID: 1-1.4:4 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
  Local Storage: total: 704.24 GiB used: 430.95 GiB (61.2%)
    model: WD5000LPCX-75VHAT1 size: 465.76 GiB block-size: physical: 4096 B
    rev: 1A05 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC210 mSATA 256GB
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: SSD serial: <filter> rev: 1L00 scheme: GPT
  ID-1: / raw-size: 32 GiB size: 32 GiB (100.00%) used: 17.9 GiB (55.9%)
    fs: btrfs dev: /dev/sdb2 maj-min: 8:18
    used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 205.97 GiB size: 205.97 GiB (100.00%)
    used: 71.6 GiB (34.8%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
  ID-4: /var/log raw-size: 32 GiB size: 32 GiB (100.00%)
    used: 17.9 GiB (55.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
  ID-5: /var/tmp raw-size: 32 GiB size: 32 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 53.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2514
  Processes: 287 Uptime: 44m wakeups: 2 Memory: 15.51 GiB
  used: 2.36 GiB (15.2%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1285 lib: 318 Shell: fish
  v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
  System install date:     2022-05-12
  Last full system update: 2022-05-22
For me, it is configured in System Settings under Shortcuts->Applications->Konsole
How strange...It's apparently missing from the fresh install but still works until it just stops working. Here is the inxi from the VM install I just made and a screenshot of the shortcut settings....
╭─user@gbox in ~
╰─λ garuda-inxi
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=5e438659-4a41-40af-bb36-0129e9419795 rw rootflags=subvol=@
Type: Virtualbox System: innotek GmbH product: VirtualBox v: 1.2
serial: <superuser required> Chassis: Oracle Corporation type: 1
Mobo: Oracle model: VirtualBox v: 1.2 serial: <superuser required>
BIOS: innotek GmbH v: VirtualBox date: 12/01/2006
ID-1: BAT0 charge: 49.5 Wh (99.0%) condition: 50.0/50.0 Wh (100.0%)
volts: 10.0 min: 10.0 model: innotek 1 type: Unknown serial: N/A
status: N/A
Info: model: Intel Core i7-2820QM bits: 64 type: MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: N/A
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 32 MiB
desc: 4x8 MiB
Speed (MHz): avg: 2293 min/max: N/A cores: 1: 2293 2: 2293 3: 2293
4: 2293 bogomips: 18340
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: mds mitigation: Clear CPU buffers; SMT Host state unknown
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.19.0.0 ports:
active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
Virtual-6, Virtual-7, Virtual-8
bus-ID: 00:02.0 chip-ID: 15ad:0405 class-ID: 0300
loaded: vmware unloaded: modesetting alternate: fbdev,vesa gpu: vmwgfx
Screen-1: 0 s-res: 1774x1028 s-dpi: 96 s-size: 469x271mm (18.46x10.67")
s-diag: 542mm (21.33")
Monitor-1: Virtual-1 mapped: Virtual1 res: 1774x1028 hz: 60 size: N/A
modes: max: 1774x1028 min: 640x480
OpenGL: renderer: SVGA3D; build: RELEASE; LLVM; v: 2.1 Mesa 21.3.7
direct render: Yes
Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0
v: kernel bus-ID: 00:05.0 chip-ID: 8086:2415 class-ID: 0401
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: d020
bus-ID: 00:03.0 chip-ID: 8086:100e class-ID: 0200
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
driver: piix4_smbus v: N/A modules: i2c_piix4 port: N/A bus-ID: 00:07.0
chip-ID: 8086:7113 class-ID: 0680
Local Storage: total: 37.96 GiB used: 79.27 GiB (208.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: VirtualBox model: VBOX HARDDISK
size: 37.96 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1.0 scheme: MBR
ID-1: / raw-size: 37.95 GiB size: 37.95 GiB (100.00%)
used: 6.06 GiB (16.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 37.95 GiB size: 37.95 GiB (100.00%)
ID-3: /var/log raw-size: 37.95 GiB size: 37.95 GiB (100.00%)
ID-4: /var/tmp raw-size: 37.95 GiB size: 37.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.76 GiB used: 0 KiB (0.0%) priority: 100
Message: No sensor data found. Is lm-sensors configured?
Processes: 201 Uptime: 1m wakeups: 41 Memory: 7.76 GiB
used: 1.09 GiB (14.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1126 lib: 281 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date:     2022-05-22
Failed units:            bluetooth-autoconnect.service
I don't understand how it's working in the VM, but glad I mentioned it. I will add the section to my actual install. Thanks, @dalto .
EDIT: Looks like my Copy Screenshot to Clipboard button is broken too. Had to save it to get it up here. Wasn't pasting right.
EDIT2: The iso is ....Well I went to Dolphin and hit rename to copy the iso name, accidentally deleted the name, and without a cancel button, tried to save it clicking the X before hitting Enter. Didn't work. The name was deleted. They should rethink the way the Rename button works and make like other file managers with a way to cancel the rename. The way they have it sucks. I just haven't installed Thunar yet.
In Dolphin just hit the Escape Key { esc }.
Hahaaa! I actually thought of that after and wondered if it would’ve worked. Thanks for the info. You answered the question in my mind. I also wondered about killing it with killall or htop or even kill PID, but I really haven’t used kill since finding out htop was interactive…lol.
This is easily reversed when using Dolphin. If you make a mistake renaming, simply leave the name blank and left click with the cursor onscreen. If you leave the name blank, when you click the name will automatically revert to the original name.
Also another handy Dolphin feature is adding buttons to its GUI. Simply add an undo/redo button and you can automatically undo rename/delete and move operations. Easy peasy.
Now that you mention it, I’ve seen that. I actually like Dolphin very much. I only add Thunar for if I want a root file manager because…well i don’t remember why…I think I had trouble running dolphin as root. And that was before I saw the root options in the right click menu. I don’t add Thunar anymore, really. I just said that because I was mad that it deleted the iso name and I failed to save it. I appreciate the tips, guys. Dolphin makes thunar look like an elementary school program.
GUI programs should really not be executed as root. An excellent alternative is the TUI program Midnight Commander. It is a dual pane file manager that runs in terminal, but has full mouse support. It has many powerful features that can be easily run as root with:
sudo mc
Midnight Commander (mc) is a real life saver utility.
That’s funny. I just told @mandog in a PM that I probably have some bad practices that need correcting like an hour ago. And that must be one. I honesty do most file management without a flie manager, I was just trying to grab a name quickly while in mid sentance, but mc sounds interesting. I’ll take a look.
I do, however, love the extract button in file managers because I haven’t learned to extract some archive formats in the command line yet.
MC is an excellent terminal program with full double click mouse support. The only downside is it is a little garish with its default color scheme. You can however install alternate skins to match your default color scheme.
If you read the documentation you can even create shortcuts to start the file manager in 2 predifened different directories as root or as a regular user.
It has a built in text editor for root config editing and is truly an amazingly poweful program. I can't recommend mc enough.
That's great, @tbg !! I love terminal programs. Thanks!
