Hi team,
I want to use the Slovak keyboard as default. The normal characters are working, even the special characters on the numbers row (ľ, č, ž, etc.). The problem is, when I want to use other special characters. For example ctrl+alt+v should give me the @ sign, ctrl+alt+e should give me the Euro (currency) sign. The signs are shown in the previous of the keyboard. For now, I am using keyboard switching with an US keyboard (via alt+meta+k). My actual keyboard is a Keychron Q5. I am not sure, if the SK keyboard does not support the ctrl+alt+key features, or it is a Wayland issue.
Here the inxi, as required by the troubleshooting law:
Kernel: 6.7.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e69eb184-4f60-4c60-a81f-aa5e53e9580b rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2214
date: 01/02/2024
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 1071 high: 4393 min/max: 400/5050 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4393 2: 3943 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 3602 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 134403
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: Sapphire NITRO+
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3,HDMI-A-3
bus-ID: 0e:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 40.0 C
gpu: amdgpu,amdgpu display-ID: 0
Monitor-1: DP-1 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.4-arch1.2
navi31 LLVM 16.0.6 DRM 3.56 6.7.2-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 23.3.4-arch1.2
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 23.3.4-arch1.2 device-ID: 1002:164e
16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.4-arch1.2 (LLVM 16.0.6)
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0e:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
API: ALSA v: k6.7.2-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:15f3
Local Storage: total: 2.73 TiB used: 470.02 GiB (16.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 37.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 35.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 122.07 GiB (6.6%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
used: 122.07 GiB (6.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-1: swap-1 type: zram size: 62.02 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.5 C mobo: N/A
GPU: device: amdgpu temp: 42.0 C mem: 49.0 C fan: 0 watts: 15.00
device: amdgpu temp: 40.0 C
Processes: 384 Uptime: 1h 33m wakeups: 0 Memory: total: 64 GiB
available: 62.02 GiB used: 7.4 GiB (11.9%) Init: systemd v: 255
pm: pacman pkgs: 1459 libs: 457 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date: 2024-01-25
Last full system update: 2024-01-30 ↻
Any help is appreciated.
